Ask an Expert Forum mini BGA 8.7x7.2
  • Subscribers 303 subscribers
  • Views 187 views
See a helpful answer?
mini BGA 8.7x7.2
Hi I need to create a mini BGA component, the dim are 8.7X 7.2 mm and has 48 pins, (6x8), how can I create this BGA that it is not square? the IC is a "ISSI 62WV51216ALL-39230 (BGA)"
Thanks...
imageISSI 62WV51216ALL-39230 (BGA).pdf
  • danteo
    0 danteo over 12 years ago
    On page 15 (your pdf) is the detailed land pattern, you need to use the E1/D1 and e, also you can draw the whole IC for placement reasons.
    BSC (basic spacing between centers) is e=0.75mm
    D1=7e
    E1=5e
    The pad diameter is b.
