Ask an Expert Forum 16 point selector ic
  • Subscribers 339 subscribers
  • Views 709 views
See a helpful answer?
So the title may be a little silly, as im not entirely sure what the name is im asking for, but basically i wanted to have something like a counter, except it has 16 outputs that all select up one by one. in case i havent asked this correctly, the purpose for this is i want to have one switch the switches up through 16 bus switches to enable 1, and have the rest disabled. having the ability to count down again would be good as well, but not necessary.
Thanks everyone
    Jason;
    Try the CMOS 4514.  It will output 1 of 16 depending on binary code you put on the input select lines.
    http://www.farnell.com/datasheets/71991.pdf
    It can be driven by a binary counter such as the CMOS 40193, which I believe is presettable, and will count up and down.
    http://focus.ti.com/lit/ds/symlink/cd40192b.pdf
    This should do exactly what you describe.
    thanks! thats exactly what i am looking for. image
    Glad I could help.  Good luck with your project!!
  • YT2095
    0 YT2095 over 13 years ago
    the TTL version 74150 is another good one.
