Ask an Expert Forum Actuator switches which one?
  • Subscribers 339 subscribers
  • Views 769 views
See a helpful answer?
i want a sensor working on less than 500 milliamps to turn on a 12V 15 amp ciruit on my boat ;  the switch to do this is an actuator switch ? which one will do the trick please?
  • Catwell
    0 Catwell over 13 years ago
    Nich,
    A relay comes to mind...
    A sensor trips the relay, that simple.
    What do you plan on sensing?
    C
    0 e14 Contributor over 13 years ago in reply to Catwell
    I think i found acctuator switch
    Helarc 4 pin 30 amp
    9654.00007
    This will get triggered by  the Watertank level sensor with half and full level switches
    Liquid level sensor
    001305 SSL
    With full sense alarm output
    240 ohms empty
    30 ohms full
    500 miliamps
    www.wemausa.com
    Hope it works!
    Sent from my iPhone
  • Catwell
    0 Catwell over 13 years ago in reply to e14 Contributor
    Keep us posted on the results.
    If it doesn't work.. a liquid sensor in combination with a relay will do the job... We will help you with that if need be.
    C
