Ask an Expert Forum Material used for Peltier thermoelectric modules casing/shell
  • Subscribers 326 subscribers
  • Views 154 views
See a helpful answer?
I wish to tryout the Multicomp Peltier thermoelectric modules in cascade for cooling an LNA block of a sensitive microwave band receiver.
1. What is the material used for the shells of these modules, eg MULTICOMP - MCPE-127-10-13 - PELTIER COOLER, 38.1W?
2. Do you have  dielectric constant values for this and similar of your products across a range of frequencies, ie 10 MHz, 100MHz, 500MHz, 1Ghz, 2GHz, 5GHz, 10 GHz
3. What adhesive should I use to bond these modules together? Do you have any material data ie dielectric, thermal properties, on the adhesive?
Kind regards,
Julian Grodzicky
PS Apologes for my login name (MyOtherHead) - I haven't worked out yet how to change it.
