Ask an Expert Forum streaming logged data to ascii
  • Subscribers 315 subscribers
  • Views 460 views
See a helpful answer?
I have an analog signal 0 to 10 volts. I need to capture this signal convert it to digital and generate ascii sentences depicting discreate numbers {1.0, 1.5, 2.0, 2.5, 3.0, 3.5 ... 20} that correlates with the analog signal. Can this be done with a data logger?
  • robotop
    0 robotop over 12 years ago
    Hello, I programmed a very simple FreeBasic application (freeware) that uses simple hardware interface to connect with a very low cost digital multimeter capable of serial data output. This streamed data is packeted with simple protocol, but the program translates it in pure ascii strings. If interested, look at my blog at this url: http://ficara.altervista.org/?p=1602
  • gadget.iom
    0 gadget.iom over 12 years ago
    How about using an Arduino (or similar device) to capture the analogue input through a voltage divider, then stream the digital value out over serial?
