Ask an Expert Forum Have an Idea, no idea what is needed to do it.
  • Replies 7 replies
  • Subscribers 305 subscribers
  • Views 614 views
See a helpful answer?
Hello everyone,
I have a idea for a Project and have no idea what would be needed to control it, and i am willing to learn how to program it. I am just looking for a little help to get me going int he right direction.
The idea is to have a RGB 3 color LED Matrix, no more than 6X6. Have it loop one animation in one color, with a looping sound. By pressing a button it would change color, animation and sound, and by pressing another switch looping the final color, animation and sound.I know I would need a Micro Controller, a soundboard of some kind with an amp, and the tricolor LED matrix.
The issue is I do not know what hardware would be needed. and I would like to be able to fit it in a small space, roughly 1 inch by 2.5 inch, by .5 inch deep at some time. I don't expect it to fit in the first version. But that would be a goal after learning.
Once again I am not asking for anyone do this for me, I very much want to learn it. I just have no idea what hardware would be needed and where to start learning the code needed.
Any suggestion or nudges in the right direction would be amazing help.
Cheers,
Agent4834
    michaelkellett over 12 years ago in reply to johnbeetem +1
    You could look at http://www.aliexpress.com/w/wholesale-ws2812.html for some ideas about what might be available. I can't offer any experience about sending money to any of these companies but the prices…
    Hi William , I just joined element14 and in the same boat as you. What is your Project?
    Mine is controlling the basic function of my computer by using Bluetooth on my Ipad mini
    0 dougw over 12 years ago
    Hi William,
    The lowest cost controllers are probably Arduino - almost any version would be adequate although it is simpler to get started with one that has built-in USB. You might prefer a zbasic module as they are even simpler than Arduinos.
    The sound for either controller could be generated with an Arduino sound module based on the WT5001 chip.
    The LEDs could be a matrix of adressable LEDs based on either a WS2801 or a WS2812. The WS2812 includes the RGB LEDs but you can get assembled WS2801 modules with LEDs mounted.
    Doug
    Other low cost audio module solutions are based on WTV020.
    Doug
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to dougw
    Adafruit has various RGB LED arrays and tutorials of how to use them.  RGB LEDs aren't cheap, but this should help you get an idea how to get started.
    You might also check out sparkfun.
    0 michaelkellett over 12 years ago in reply to johnbeetem
    You could look at
    I can't offer any experience about sending money to any of these companies but the prices are low !
  • robotop
    0 robotop over 12 years ago
    Hello, an alternative solution may be to use a cheap chinese tablet as development system, and write an Android application that "simulates" your square 6x6 rgb leds matrix. The sound capabilities are very easy to implement (like coloring the 6x6 simulated led matrix) and the whole program can be written with B4A (Basic for Android). An old wm8650 tablet, resistive touch screen, can be purchased for less than 50$ , so you can test your idea with high level language, low cost hardware, no solder iron ; if satisfied about the results, then you can approach a microcontroller solution, but I think it will be more expensive than the tablet... Consider that any RGB led needs for 3 different duty cycle percentages to assume every possible colour... and this must be done while scanning the 6x6 matrix and any delay, latency, service interrupt can make the display "flickering". Believe me, if you check your idea on a tablet (or on PC) you can achieve better results, and very quickly. Ciao
  • dwinhold
    0 dwinhold over 12 years ago
    Buying a 6x6 color matrix might not be as cheap as making one. I just bought 5mm color LED's for a cube I am building for $11 per 100, they sell them for $7 per 50 (eBay). I agree with Mr. Wong that Arduino will be a great controller, they are fairly easy to learn with great results. They have expansions for sound and buttons for when you want to change the display. A breadboard would be a good thing to have as well while you are designing and building your first project. The first one you make most likely will be bigger then you want, but once you have it working you can make it smaller to what you want.
    Hope this helps,
    Dale
