Ask an Expert Forum power LED's
  • Replies 18 replies
  • Subscribers 342 subscribers
  • Views 2905 views
See a helpful answer?
power LED's
greenwald1818
greenwald1818 over 12 years ago
hi,
     I was wondering, im building a raspberry pi laptop, and I need a way to tell if the battery is low. so, what part would I need to get if I get 2 LED'S, and I want the blue one to be on if the battery is full and the amber one to be on if it gets below 4.5 volts (with a 7.5 volt battery) OR if I have a multi-colored one how would I do it if the same thing applies except with a multi colored one. thx in advanced.
  • saurocksall
    saurocksall over 12 years ago +1 verified
    Hi Alex, I have found the circuit that will help you , it uses The LM 3914 it has ten comparators, which are internally assembled in the voltage divider network based on the current-division rule. So it…
  • greenwald1818
    greenwald1818 over 12 years ago in reply to saurocksall +1
    what is the ic1 LM3914
  • gihu
    0 gihu over 12 years ago
    Maybe you can use an ADC over I2C, so, you can monitor the status of the battery every time you want. And ADC's like ADC121C021 has also an alarm output, so you can also use to notice the raspberry pi when the battery is low than the thershold you chose.
  • greenwald1818
    0 greenwald1818 over 12 years ago
    I have the LM3914. but what are all the other little marks and dashes.
    it would be helpful if someone could please send me links to the parts in that diagram or tell me what the marks and dashes mean.
    thankyou
  • D_Hersey
    0 D_Hersey over 12 years ago
    Well, your device measures potential between 0 AND 5V, as I understand it.  So you are probably are going to need some offset and scaling.  Is it a lead-acid battery you are monitoring?
  • D_Hersey
    Okay, just read your original post, 7.5V.  Is this Ni-Cd?  If so, potential monitoring is nearly useless, due to the flat discharge curve.
  • greenwald1818
    the battery is a lithium ion 7.5 volt battery
  • greenwald1818
    but I almost think I have all of the parts
  • D_Hersey
    Lithium has a fairly profound drop in potential with time, famously requiring boost-buck or SEPIC switchers to stabilize output.  Let me go look up the numbers. . .
  • D_Hersey
    Here is a useful link:
    Battery Fuel Gauges: Accurately Measuring Charge Level - Application Note - Maxim
