Ask an Expert Forum Need help connecting Raspberry Pi to old Com-trol MCS-4000 boards.
  • Replies 17 replies
  • Answers 3 answers
  • Subscribers 339 subscribers
  • Views 4429 views
  • raspberry
  • pi
See a helpful answer?
Hi All,
I have a Raspberry Pi V2 that I'm trying to see if I can connect them to an old Com-trol MCS-4000 control boards.
The Com-trol system had digital & analog input boards and relay output boards. The input and output board use the same IC chip. The IC chip is a p87c51sbpn. It uses UART to communicate.
The Com-trol system is powered with a 24vac transformer. They connect to the boards as (12vac, ct, ground, 12vac).
Then boards are then connected together and to the main console (MCS-4000) via the local bus. The local bus is a serial type communication.
How do I check to see if I can connect it to my Pi?
How would I get them to talk to each other?
If I can't us the boards can I just use the p87c51sbpn IC chip.
I do have PDF's for the Com-trol system if anyone needs them. They are very hard to find.
Teeterbuilt
Message was edited by: Teeterbuilt Added PDF's 12/27/13.
imageF_27262_4.pdf
imageF_28077_1.pdf
imageP87C51SBPN datasheet.pdf
  • robotop
    0 robotop over 12 years ago in reply to robotop
    Addendum...
    If you are accustomed to electronics and want to build your own interface, here is a picture of a prototype I realized for my own projects:
    The ICs used are available on Element14 (or Farnell) catalogue and are:
    a) the usb interface FT231XS (1,86 Euros for 1 pc - look at this link:
    http://it.farnell.com/ftdi/ft231xs/i-f-usb2-0-fs-to-f-l-h-s-uart-20ssop/dp/2081328 )
    b) the ttl to rs485 interface SN65HVD3082ED (1,68 Euros for 1 pc - look at this link:
    http://it.farnell.com/texas-instruments/sn65hvd3082/transceiver-rs-485-smd-65hvd3082/dp/8452210 )
    Follow the data sheets and application notes for the remaining parts.
    Note that under linux you have to change the ID of the FTDI chip (it's a very new part) in order to make it recognizable by the system.
    Look at the FTDI site for a tool that can modify many parameters inside the chip, including the ID, then modify this in order to appear as FT232RL.
    Hope this helps, bye.
    Thanks Emilio.
    I found a usb rs485 on amazon. Was wondering if this one would work.
    http://www.amazon.com/Estone-Converter-Adapter-Support-WinCE5-0/dp/B00HGA1UZG/ref=sr_1_10?s=audio-video-accessories&ie=UTF8&qid=1389234223&sr=1-10&keywords=rs485
    Teeterbuilt
  • robotop
    0 robotop over 12 years ago in reply to e14 Contributor
    Hello, yes, this can work, but ONLY at short distance and with devices with common ground. Note that the board has a connector with only 2 contacts... this means that the common wire is absent. The RS485 is a differential mode transmission, so one wire has opposite polarity respect to the other and apparently this is enough to transmit data, but connecting one device on a certain location with another device in a different location, without a common wire (a ground with small resistor) it will happen that both the signals are at level that goes out if the input max (or min) voltages admitted by the device. This can happen if the ground level of the transmitting and receiving circuits are different. In the real world this happens very frequently, expecially on large distances. Using a 485 connection with only the A+ and B- wires may work only with devices that have the same ground level (or the difference is in the range accepted by the devices). I don't believe that the interface you found is FTDI chip based (it's VERY low cost), so may be you can have some problems with the linux driver (not all chips are recognized), but you can give it a try... In my opinion, it's better if you invest some money over and find an interface that will be surely supported by the Raspberry's OS. Hope this helps, bye.
    0 e14 Contributor over 12 years ago in reply to robotop
    Emilio,
         I would like to build the usb to rs485 adapter but I am very limited in circuit / component knowledge. I am good at trouble shooting and fixing electronics. I am also good with a soldering iron. I dont know if it would be cheaper and easier to build one or just buy one. I have found another usb to rs485 & 422 adapter.
    http://www.amazon.com/RS485-RS422-Serial-Adapter-Converter/dp/B00H8V19KY/ref=sr_1_4?s=audio-video-accessories&ie=UTF8&qid=1389313935&sr=1-4&keywords=rs485
    Thank you for your time.
    Teeterbuilt
  • robotop
    Well, I don't know if you have a "contract" with Amazon for that great amount of links... but surely I haven't one with ebay image  The device you linked may be working (it offers a linux support) but I never tested it and can't warranty it will work. I just can suggest this, that I purchased before developing my own. I developed an application under puppy linux with this interface without any problem. The link is:
    http://www.ebay.it/itm/LJN-USB-to-RS485-FTDI-interface-Board-FT232RL-75176-New-/151131138209?pt=LH_DefaultDomain_0&hash=item23301e28a1
    Hope that the link policy of this site would admit ebay links...bye
    Emilio,
         Thanks. No I don't have a contract with amazon I just didn't think of ebay.
    Teeterbuilt
    Hi Emilio.
    I'm a bit interested in your application for the USB-to-RS485 board. I have the same board, but I can't seem to recieve the information from the RS485 communication.
    I have a solar inverter (RS485 two wire) connected to the USB port on the Raspberry using the board, but I can't read any of the data.
    Can you help me out?
    Best regards
    Mikkel
