Ask an Expert Forum electronic workshop
  • Answers 2 answers
  • Subscribers 306 subscribers
  • Views 528 views
  • electronic
  • work_place
See a helpful answer?
electronic workshop
HI everyone my name is Nathan Weber. I am sort of new to this kind of stuff and i was wondering if I could you guys and girls some questions?
My first question is what would be a suitable workshop setup
and my second is what would be a good beginner project arduino project that utilises  remote control cars
would look forward to hearing from you guys
    dougw over 12 years ago +1 verified
    Hi Nathan, Here is a list of workshop items in order of importance.. PC hand tools - screw drivers, needle nose pliers, tweezers, side cutters, scissors, wire strippers, etc. solderless breadboard breadboard…
    0 dougw over 12 years ago
    Hi Nathan,
    1. PC
    2. hand tools - screw drivers, needle nose pliers, tweezers, side cutters, scissors, wire strippers, etc.
    3. solderless breadboard
    4. breadboard jumpers
    5. DVM
    6. 5V power supply
    7. adjustable current power supply
    8. optical magnifier
    9. temperature-controlled soldering station with wet sponge and solder
    10. vice and third hand
    11. oscilloscope - DS203 is the minimum, Rigol DS1102E preferred
    12. signal generator
    13. stereoscopic microscope
  • Kilohercas
    0 Kilohercas over 12 years ago in reply to dougw
    Right now i only have PC, scope, solder iron, and some hand tools, that all you need to start. If you can't do by using only that, nothing gonna help.
    But right tools can make job much easier
    Since Douglas answered the first question, I will try to answer the second part.
    Ideas to implement:
    1 - Control the speed of the remote control car, and if done add an array of LEDs to show how fast it is going (one LED turns on as the speed increases).
    2 - Try to locate the position of the car from a reference point.
    3 - Try to make the car to rotate around itself (360 degrees in one spot).
    4 - Auto parking system (might be advanced).
    5 - Auto stop (if it sense that it will bump into anything then it stops).
    These are some ideas to implement if you will use Arduino along with a remote control car.
    A.A
    0 Former Member over 12 years ago in reply to Former Member
    Thanks for the reply great help
