Ask an Expert Forum 3d printer steps
  • Subscribers 339 subscribers
  • Views 675 views
  • huxley
  • printer
  • 3d
  • calibration
See a helpful answer?
3d printer steps
I have a reprap pro huxley 3d printer and by printing a calibration peice found out I need to change the steps per mm on the y axis but don't know how to do it!
So where do I go to change it?
It's a Melzi board and im using Cura software by ultimaker.
  • Nate1616
    0 Nate1616 over 12 years ago
    hey Jack
    If you need to calibrate your Huxley then you will have to figure out what firmware your Melzi is running.  The most common is Sprinter or Marlin but I would just ask whoever you bought it from.  So you will not do anything with the software (Cura) as this just acts as the interface between the gcode and the printers firmware.
    I would also move this post into the 3D printing discussion as this would be more of a logical place.  If you have any other questions once you figure out what firmware its running don't hesitate to ask.
    Nate
    0 e14 Contributor over 12 years ago in reply to Nate1616
    I figured it out, its working great now! thanks for the help image
