    • Avnet Boards Community
Ask an Expert Forum Ethernet/Wifi Based RFID Controller with Color 3.5" TFT Color LCD
  • Replies 17 replies
  • Subscribers 289 subscribers
  • Views 1359 views
  • wifi
  • lcd
  • ethernet
  • rfid
  • microcontroller
See a helpful answer?
We are looking to design a Ethernet/WIFI based RFID controller with 3.5" TFT Color LCD for our application. We have narrowed down the ATMEGA328 MCU initially but we found out that for a color LCD and ARM MCU is recommended. Can anyone advise on the components to be used for such a project based on their experience or knowledge. Will appreciate if someone can share any sort of electronic circuit diagrams or PCB design documents.
Please feel free to ask me any questions regarding this project. Thank you
Regards
    0 dougw over 11 years ago
    Hi Osman,
    How about a TI Tiva C TM4C1294 Launchpad?
    It has an ARM Cortex M4 with ethernet and you can get a QVGA Booster Pack that plugs right in.
    Doug
    0 Former Member over 11 years ago in reply to dougw
    Hi Doug,
    Thanks for the reply. The pricing of the booster packs components gets way higher then our budget and also the launchpad has only two ports for boosterpacks. We can use one for Wireless and the other for Display but how do we embed RFID.
    Do you have any launchpad in mind with only Wifi no Ethernet. Thanks.
    0 dougw over 11 years ago in reply to Former Member
    Hi Osman,
    Maybe you could use a USB WIFi dongle and an RFID Booster Pack.
    There are several other platforms that could handle this, such as Arduino Yun, but if you put together a complete specification, it would be easier to optimize a solution.
    What functions need to be performed and how fast? Power requirements? Cost? What user interface? etc...
    Hi Doug
    We are in the amusement industry and we have recently developed our in house POS and now were taking it to the next level to integrate it with RFID Debit cards. We had some equipment developed from a local vendor and they claim that they've designed their own 3 layer PCB using atmega328 MCU but were facing problems with their support. So I've been given a go ahead from my management to do this in-house as we have more than 400 rides in different locations and expanding More.
    What we need is a Rfid based controller which can connect over WiFi to the main server which in turn will be integrated with our pos server. When a customer comes and gets the card loaded with cash they can use that as a debit card on each ride and a screen will display the ride amount and later the balance amount if the ride is activated or insufficient funds if there are not enough funds. We've been doing our research and came across arduino, ti, raspberry pi etc launchpads but don't know which is better than then other.  Our numbers for the controller calculated so far indicate that we should be able to get the controller for somethig around 60-70 USD. We could be wrong and open to suggestions.
    I hope the scenario is clear and were open to suggestions. Thank you.
    Pl excuse any mistakes as I'm writing from a Mobile phone.
    Hi Osman,
    This sounds like an interesting application.
    If it was my project, I would design a custom circuit board so I could optimize power, size and features. However, it is certainly possible to build a functional prototype from off-the-shelf modules, but it will likely be pretty big and clunky and may have reliability problems due to all the connectors. If you do build a system from standard modules, it might be worth using modules that are based on open reference designs, so you can easily incorporate appropriate sections of the circuit in a fully custom design and avoid a lot of software modification - if and when you choose to shrink the design.
    Normally decisions about which platform to use need to take into account things like which development tools your development team is familiar with, potential component obsolescence, and which software language your developers prefer.
    To make an optimum decision, you probably need to put a complete specification together of all desired features and performance and rate various solutions against the list.
    I could say that an ARM Cortex M4 is about the minimum MCU power you need unless you use a dedicated WiFi module, but a lot depends on how strong your software team is and what performance level you want.
    Hi Doug,
    Yes it is indeed an interesting project and we hired a professional to design the electric circuit from scratch but apparently his arrogance and attitude has literally shattered our trust and the device has been developed with alot of minor glitches which being in the amusement business are not acceptable. He is not willing to share his circuit designs with us now and basically exploiting us by not sharing the RFID frequency so we have to get the cards encoded by him and he is charging us for every single card. We only have 35 of these made which are not aesthetically or technically what was agreed upon initially. Therefore, we have decided to do our own R&D and undertake this project in house.
    We believe by using off the shelf boards and using them in a professional way we can come up with a very nice product. Our first phase is very simple, we are using an Arduino Ethernet Board with Atmel MCU available on Arduino website. This will work with a 16x2 LCD and a RFID Module, we have the capability in-house to design the firmware both in C/C++ and Java, but it will not be a problem to find a resource who can also work in assembly if needed. What we need is the right hardware at the right price with best quality. Going for a complete ground-up design will require more time and that is what we don't have at our hands plus in our country we don't have good quality PCB fabricators available so even if we do that we will have to get the PCB fabrication done from China or Taiwan as they are cheaper and will be of good quality.
    So once we are done with the 16x2 controllers we want to shift to Wifi and Color LCD and we have already started working on our R&D so we can kickstart the prototype and testing phase asap. Looking forward to your reply. Thank you.
    Hi Osman,
    depending on legalities, perhaps you could use an inexpensive commercial RFID reader/writer to figure out what frequency is used and it probably could be used to monitor the protocol as well if needed and even program new tags.
    You could get a WiFi module for your arduino for under $20 and a color touch screen (QVGA) for about $17 if you want to stay with the same platform.
    Hi
    How about using a stm32 discovery board with 3.5" tft, stm WiFi expansion module and an id20 RFID reader module. We thought if we are doing it again let's do it the right way and get all the features implemented. Please suggest if his hardware will be good for commercial use if the packing is done professionally. Thanks
    0 michaelkellett over 11 years ago in reply to Former Member
    The ST discovery board is a development board, not  a production component (ST make no claims about long term availability or suitability of production use) . You would do much better to take Douglas' advice and use ready made development boards for development and then design a custom board. Don't be put of using contractors/consultants to help with the work because you have had one bad experience - next time you'll know much better what to look for and what to write into the contract. (Like that the circuit and design and IP belong to you, set up payment milestones which require the handover of documents etc.).
    0 Former Member over 11 years ago in reply to michaelkellett
    Thanks Michael
    When it comes to designing the boards we have time constraints now. And the consultants that we've met are asking for at least 3 months for design and simulations. Therefore we decided to go for off the shelf boards to reduce the time to market. Any comments.
