Ask an Expert Forum need help knowing if this motion sensor will work with this board
  • Subscribers 303 subscribers
  • Views 287 views
See a helpful answer?
hi i want to know if a PIR Motion Sensor Module would be able to work wit a light o rama InputPup
links to the parts will be below and i would appreciate if someone could help me as i am new to this stuff and want to
make sure i don't have any problems
light o rama inputpup http://www1.lightorama.com/inputpup/
pir motion sensor module https://learn.adafruit.com/pir-passive-infrared-proximity-motion-sensor/overview
hope to get a respons soonimage
    0 dougw over 11 years ago
    Hi Rian,
    It looks like the PIR goes high (3V) when it is triggered but the InputPup expects a switch to ground (low) trigger.
    To invert the PIR signal you could connect an open drain FET transistor to the PIR. A BS270 or VN2222 should switch fine with 3V.
    Doug
    0 Former Member over 11 years ago in reply to dougw
    thanks heaps image
    thanks heaps image
