Ask an Expert Forum Where I can find battery management circuits like the OpenUPS?
  • Subscribers 337 subscribers
  • Views 730 views
  • charging
  • ups
  • batteries
  • power-supply
  • laptop
See a helpful answer?
cdahmedeh
cdahmedeh over 12 years ago
I'm working a custom laptop project where I want to include a rechargable battery. I decided on a few requirements which are as follow:
  • Uses Li-Ion chemistry for the batteries themselves.
  • The output voltage should be 12V.
  • The system should handling switching between external power and batteries seamlessly.
  • The system could be used while charging.
  • The system can report information to the computer about battery capacity and discharge rate.
Essentially, I would want an uninterruptable power supply, that uses battery backup. Similar to how laptops work currently.
I found a product that does exactly what I wanted called OpenUPS. It is sold by Mini-Box.com right here. I have tested it and it works great, however, it is very expensive and a bit overkill in terms of features.
Are there similar products I can find (I'm looking for a kit similar to OpenUPS, and not just an IC chip) that are perhaps simpler and more cost effective? What other solutions should I consider?
Thanks!
Ahmed
