Ask an Expert Forum Battery charger current draw calculation
  • Replies 9 replies
  • Subscribers 339 subscribers
  • Views 2118 views
  • charge
  • battery
See a helpful answer?
Hello Everyone,
Lately I have been trying to figure out how to calculate the current draw of circuits but I ran into a problem with battery charging circuits. My question is whether to plug in the battery to the circuit to obtain a correct reading?
Thank youimage
  • D_Hersey
    0 D_Hersey over 12 years ago
    Sure, why not?
    0 e14 Contributor over 12 years ago in reply to D_Hersey
    I was wondering whether the battery made a difference when calculating the current, though my circuit has a voltage regulator that the output goes to the battery instead of the battery being in the initial circuit.
    0 dougw over 12 years ago in reply to e14 Contributor
    It depends where you are measuring the current.
    If you measure current to the regulator, you can't tell how much is going into the circuit, how much is going into the battery and how much is coming from the battery. If you disconnect the battery, you can determine current to the circuit, but if the voltage changes when the battery is inserted, the current may also be different.
    If you measure at the output of the regulator and battery, it will capture all current to the circuit, but will not indicate how much is being used to charge the battery nor how much is coming from either supply.
    You may need to measure at more than one place to know everything.
    0 e14 Contributor over 12 years ago in reply to dougw
    I am using ohms law to calculate the current, so I am measuring the resistance across the input terminals so does the resulting calculation produce the maximum current draw from the circuit?
  • D_Hersey
    You never want to hook up the leads of your Ohmmeter to a power source.
  • D_Hersey
    An ideal voltmeter has infinite input impedance.  Therefore, if you hook it up to a current source, you will cause it to provide infinite power.
    An ideal ammeter has zero input impedance, therefore, it you hook across a voltage source, you will cause it to provide infinite power.
  • D_Hersey
    Current is measured through a point.  Your current meter has a maximum safe value it can measure.  If this is greater than the current you anticipate, go ahead and break the circuit and and insert your ammeter and charge the battery through it.  This presumes your ammeter is bipolar, otherwise, mind the polarity.
  • D_Hersey
    For  more permanent solution, get a shunt resistor and a panel meter.
    Okay, thank you for your help. image
