Ask an Expert Forum DRV102!
  • Replies 16 replies
  • Answers 2 answers
  • Subscribers 316 subscribers
  • Views 2586 views
See a helpful answer?
DRV102!
regarding the duty cycle of TO220 How to adjust the duty cycle continuously for example from 20% to 50% to 90% and so on at one operation?
    0 Former Member over 11 years ago in reply to D_Hersey
    thanks a lot
    which uP board u think it has an analog output??
  • D_Hersey
    0 D_Hersey over 11 years ago
    You know, that may have been a little pre-prandial persnicketiness on my part, there are worse things than being a little Rube Goldberg in this discipline.
    There would be nothing wrong with using a PWM out to control this, my aesthetic judgements couldn't be further from relevance.  You need to attach a circuit called an LPF to get a continuous-like output after your PWM.  This can be made with an op-amp or two and some (RC) passives.  Longer period of integration yields more accuracy but slower response time.
    Why don't microcontrollers generally have on-chip DACs? - Electrical Engineering Stack Exchange
    thanks a lot
    0 jw0752 over 11 years ago in reply to Former Member
    This makes sense to me. What you are saying is that you would program the arduino to adjust its PWM output to control an DAC circuit which in turn would supply the desired voltage to the Adjust pin of your IC which would produce the desired power duty cycle to your solenoid. If you have a sensor, on the actuator, that can feed back to the arduino you will be able to regulate the travel of the actuator.
    Also Don is very correct in pointing out that if you do use a potentiometer for control of the adjust pin it would be good practice to tie down the loose end of the potentiometer to the wiper.
    0 jw0752 over 11 years ago in reply to D_Hersey
    Don I really enjoy your posts, they make me smile. Until I met you on this forum I had not cracked a dictionary in 10 years. Now I have to keep one, (a big one at that) next to my computer. Besides learing electronics I am getting a side course in vocabulary. Yes we have finally thawed out, 90 degrees today, you should get it tomorrow.
    Sorry Aboabdullah for chit chat in the middle of your thread.
  • D_Hersey
    Well John, I appreciate that you take me in good humor, I kid incessantly and am horrified whenever people mistake me for serious.  Sometimes I get the mealtime megrims when I am peckish and am less restrained even than usual.
    Sorry as well for chatting on your post, I started it.  If you have any need any further assistance, Aboabdullatef, please feel free. . .
