Ask an Expert Forum Help please
  • Replies 10 replies
  • Subscribers 316 subscribers
  • Views 1004 views
  • keyboard
  • help
  • hack
See a helpful answer?
Help please
I'm hacking a usb keyboard to my arcade, and I want know if is possible use a analog stick (PS2, XBOX, PS3 or Arduino) in my hack. Can I use the joystick to my usb keyboard. Please help.
  • toxxn
    0 toxxn over 11 years ago
    If you provide a little more information relating to what you are trying to do with your keyboard and analog stick I may be able to assist you further.
    If you are simply asking if you could use an analog stick so emulate keystrokes of a keyboard, such as up on the analog emulating up on the up arrow key, then yes you can.
    This would require a little bit of soldering work, but it is fairly simple and straight forward.
    Might I also make a small suggestion, something to maybe look at in the future. I built a custom Mame Cabinet using a Raspberry Pi and eliminated the keyboard all together using a Xin Mo 2 Player USB Kit. I picked it up on ebay for $60 and it was a full 2 player kit. Here is a link if you would like to check it out.
    http://www.ebay.com/itm/2-Player-Mame-Arcade-USB-Kit-w-2-Joysticks-4-8-way-16-Push-Buttons-60-in-1-/221471126662?pt=LH_DefaultDomain_0&hash=item3390b53486
    Essentially its a full arcade joystick/ button setup that you can connect via USB.
    0 Former Member over 11 years ago in reply to toxxn
    I want use the analogic stick to emulate the keystrokes of the keyboard. I don't wanna use Raspberry Pi because is so expensive and I will need import and wait 60 days of shipping. Can you help me please?.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to Former Member
    You can use the ACD on board  an arduino to read the two pots of the joystick but the difficulty would be to get the arduino to act as a keyboard to the computer
    like this only interpreting the analog instead of buttons http://hackaday.com/2012/06/29/turning-an-arduino-into-a-usb-keyboard/
    just google https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=arduino%20keyboard%20emulator%20uno for more
  • toxxn
    0 toxxn over 11 years ago in reply to Former Member
    It is unfortunate that the Raspberry Pi is expensive for you, as there are so many different things you can do with it its almost unreal.
    But yes, it is possible to emulate the keystrokes of a computer using analog.
    I will admit though, there are other more simple options as well.
    How I can do It?
    I provided a how to above, you cant expect us to do it all for you.
    What part of the solution do you not understand
    Regards
    Peter
    0 Former Member over 11 years ago in reply to Robert Peter Oakes
    I have much difficulty to connect the joystick in the keyboard. I made the mapping of keyboard but, i dont have idea how to connect in to keyboard. Please help.
    Man this is right? http://kyorune.com/modding/article.php?id=27 ? Can I use this diagram??
    As far as how to modify one of the joysticks, it looks ok to use
    Thanks Dude image
