Ask an Expert Forum Touchscreen Display - How to test it?
  • Subscribers 307 subscribers
  • Views 772 views
  • touch_panel
  • touch-screen
  • display
See a helpful answer?
I just got a brand new 7" Touchscreen Display. However, it doesn't seem to be working.
I have unplug it and plug it all of the connectors a bunch of times But so far there hasn't even been a little signal.
I can see that it can power the raspberry pi, both using the jumper cables as well as the USB.
Is there anything I should look for before assuming that it was dead on arrival?
Thank You.
    shabaz over 10 years ago
    There are some commands to type to update your drivers, it is not plug-and-play until that task is complete.
    See here: https://www.raspberrypi.org/blog/the-eagerly-awaited-raspberry-pi-display/
    Former Member over 10 years ago in reply to shabaz
    Hello Shabaz,
    Thank you for your quick reply. I am trying to use windows 10 IoT. Have you tried this?
    Is there a set of commands/updates for Win 10 that are required? Will it work?
    Once again thank you.
    shabaz over 10 years ago in reply to Former Member
    Hi Paulo,
    As I understand, only some peripherals are supported with Win 10 IOT. Unfortunately I don't know if the display is supported - I suspect not, since it is so new.
    But perhaps the Raspberry Pi org supplied early hardware to Microsoft or worked on drivers for it. This is just speculation though : (
    I think the DOA assumption needs confirming with a known working setup, and today most users will have tested with Raspbian unfortunately.
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to Former Member
    The answer to that is "Not yet". I too am waiting for thisn and will post how too video as soon as it is possible
    I do however have some other graphical displays working under windows 10 IoT on the PI, check out my videos here Thebreadboardca
    you will find quite a few Windows 10 IoT projects by me and many others here http://www.element14.com/community/community/raspberry-pi
    Peter
    Former Member over 10 years ago in reply to Robert Peter Oakes
    Dear Mr. Oakes,
    I too am eager to get drivers and/or configuration code so that IOT can be viewed on a Raspberry Pi 7-in touchscreen display. I am extremely new to this field but I have successfully displayed Raspbian on a monitor through HDMI and a 3.5 in PiTFT display attached directly to the R Pi . I tried to use the method put forth by http://blog.falafel.com/setting-up-a-7-inch-touchscreen-on-a-pi-2-with-windows-iot-core-insider-preview/ but realized his decoder/converter was not the exact hardware as that on the Raspberry PI Brand. Nothing has worked to display IOT on the Raspberry Pi touchscreen to date. I appreciate any help you can give me and thank you for you input. Frank.
