How to make a robot which starts by hearing command "on" and stops with "off".I need a mechanism or system which is not much costly and generate high signal by hearing "on" and generate low signal with "off".
should do the trick https://www.sparkfun.com/products/12656
thanks peter.But it's costly .I need to process only two commands "on" and "off" and generate high and and low signal respectively.
Can your robot be tethered to a computer?
Tim
