Ask an Expert Forum Turning a threaded rod with a motor
  • Answers 2 answers
  • Subscribers 328 subscribers
  • Views 1084 views
See a helpful answer?
I'm attempting to build a claw machine and I want to use threaded rods to enable the claw to move around, such as how you would do it on a cnc router or 3d printer. However, I can't seem to find a way to attach the threaded rod to the motor. How would I do this?
  • turfgnome
    0 turfgnome over 11 years ago
    I would use a coupling for that either a 3d printed one or one such as this
    Rigid Couplings | MSCDirect.com
    0 jw0752 over 11 years ago
    Hi Jamie, In many cases the difficulty with getting an exact alignment requires some flexibility from the motor shaft to the threaded rod. This can be accomplished with a sleeve such as shown by Robert but using a loose fit and pins through the two shafts. I have also seen a rubber sleeve used to isolate the motor and threaded rods slightly from each other. In both cases it forms a slight U-joint that allows the motor shaft and threaded rod some latitude in their alignment. In the cases where the shaft of the motor is firmly affixed to the threaded rod I have seen the motor mounted in such a way that it can move slightly on its mounts.
    0 dougw over 11 years ago
    Also check out flexible couplings - they are designed to accommodate slight misalignments.
    e14 sells some.
