Ask an Expert Forum Resistors
  • Replies 22 replies
  • Subscribers 342 subscribers
  • Views 3193 views
See a helpful answer?
Resistors
What info do I need to order these resistors?
    jw0752 over 11 years ago +1
    Hi Jay, It looks to me like the heat has also carbonized your board somewhat. This weakens the board and may cause the pads to come loose when you try to remove the old parts. In circumstances similar…
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    So they should be able to handle the power themselves as the old ones also look to be about 500mW but you need to remember they will run hotter (Less surface area to dissipate the heat) so when you mount them, keep them raised off the board quite  way or you run the risk of burning the board
    Regards
    Peter
  • supper_slash
    0 supper_slash over 11 years ago
    @JAY MILLS
    The only thing i can say, it to try replacing 2 or so of them if you can. (the worse looking ones)
    And if possible, power the unit up, and see if they handle the heat. If they do, than replace the rest.
    I think they will. but testing is best.
    I hope what you are working on you can power up with it apart. So you can monitor them.
    I hope everything goes well, keep us posted.
