Ask an Expert Forum Resistors
  • Replies 22 replies
  • Subscribers 342 subscribers
  • Views 3169 views
See a helpful answer?
Resistors
What info do I need to order these resistors?
    jw0752 over 11 years ago +1
    Hi Jay, It looks to me like the heat has also carbonized your board somewhat. This weakens the board and may cause the pads to come loose when you try to remove the old parts. In circumstances similar…
    0 e14 Contributor over 11 years ago in reply to supper_slash
    Mine have1 brown and 3 red, that one has 1 brown, 3 black and another brown?
    While I'm here I want to thank all of you for your input..
    thanks all
  • supper_slash
    0 supper_slash over 11 years ago in reply to e14 Contributor
    Image is for illustrative purposes only. Please refer to product description.
  • supper_slash
    0 supper_slash over 11 years ago in reply to supper_slash
    The link should take you to a 2200 ohm resistor. ±1% And 600mW. I think that's RED RED RED BROWN. im just going from memory thow, someone correct me if i am wrong.
    CLICK HERE. To see the specks.
    I ordered 250, dose the size deference seem right?  How do I know what watt the old resistors are rated?The old ones read 2.20K and the new ones read 2.18K, I guess that is good but I'm worried about the watt rating.imageimage
  • D_Hersey
    0 D_Hersey over 11 years ago
    Rightly so.  Resistors have gotten a little smaller per Watt rating over the years, 'cause they can run a little hotter.  But maybe not this much.  If you had less resistors to replace, I'd tell ya to use four new resistors/resistor.  Any integer square number of equal-valued resistors can be used to make a more power-tolerant version.
    You can measure the physical dimensions of your resistors and compare them to ones in an old e- catalog.  Just to glance at the situation the resistors you have look like half-watters and your replacement ones look like quarter-watters.  Too big is better than too (contemporaneous w/ your device)  small in most cases.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to e14 Contributor
    if your concerned with the smaller resistors then connect 2 in series with 2 in parallel, this will end up with the same value within the tolerance of the resistors but it will handle much more power
    this would require 4 resistors for every one your replacing
    alternatively get higher wattage resistors
    Regards
    Peter
  • supper_slash
    0 supper_slash over 11 years ago in reply to Robert Peter Oakes
    @peter oakes
    If you had to guess, what wattage would you say the old resistors are?
    1/2 watt?
    0 Robert Peter Oakes over 11 years ago in reply to supper_slash
    What is the wattage of the new ones ?
    Hi all,
    The new one are what Lupe Lopez gave me a link to: http://www.newark.com/vishay-bc-components/mrs25000c2201fct00/resistor-thin-film-2-2k-0-6w-1/dp/97K5580, Thanks Lupe....
    They are 600mW and if a 1/2 watt is: 500mW and what I have (the old ones) are a 1/2 watt then I should be good to go. I guess there is no way to know what watt my old ones (in photo on the board) are?
    I think I'm good with these Lupe just wanted to post the size difference and get some feed back, this board was made in the early 80's
