Ask an Expert Forum Ethernet Shield Heat-up Issue - Need Help
  • Replies 18 replies
  • Subscribers 340 subscribers
  • Views 3177 views
  • of
  • issue
  • ethernet
  • heat-up
  • shield
See a helpful answer?
ramguna84
ramguna84 over 11 years ago
Sir,
We interfaced Ethernet Shield with PSoC4 Pioneer Kit and executes the Project#31 example code (after following the mentioned guidelines). The observations are:
1. Connected USB cable to PSoC4 Board for Power both boards (PSoC and Shield): We were unable to ping with IP address.
2. Connected 12VDC (1mA) adapter to Shield for power both boards: We were able to PING with Shield and run the program (LED blinks on network command (Only once)). But....boards were heated-up. After some time we unplug the power and re-tried the same but we were able to only PING and got the web page; not the LED blink response. We repeated the same but the observation is same.
Please suggest us to sort out the heating issue and get the consistent response.
Suggest us the ways to power-up the boards.
SG Ramanathan - MTech Student
National Institute of Technology (NIT) Calicut
Kerala
India
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago in reply to ramguna84
    If your still trying to use the Arduino Ethernet and the PSOC together you need to STOP. They won’t play well because there both including the micro-controller and you will only get frustrated and possibly damage one or the other boards. Read my previous response for the pictures of the two boards, look them up on the Arduino site and you will understand better what I am saying
    You need to use an “Ethernet Shield” NOT an “Arduino Ethernet” they are very different
    Peter
  • mudz
    0 mudz over 11 years ago in reply to ramguna84
    ramanathan Any Success?
  • ramguna84
    0 ramguna84 over 11 years ago in reply to mudz
    Sir,
    First of all thanks for pointing out the right mistakes at right time. Actually, we are getting it replaced with actual shield by one or two days to re-start the work.
    Meanwhile we are studying for SDcard interface in the same shield once we receive. Our project design is demanding both interfaces (SD Card and Ethernet ) using the same shield.
    If have any references to kick start the SD Card interface in that shield, you can share with us, it would be useful for us. Thanks.
  • ramguna84
    Sir,
    Good news. I had successfully interfaced Ethernet Shield today and works well except one observation that LED ON & OFF for each color worked only once (one cycle) when i retried for LED ON-OFF through web server, no response on LED. I tried re-programming, resetting boards, etc., but same response. If you have any advice please tell us. Thanks.
    Can you advice or refer any portal to inetrface the SD Card libraries along with this Ethernet project so that i can make use of both microSD Card and Ethernet interfaces in single project. Please advise.
    Ramanathan SG
    MTech Student.
    Post your code and well have a look at it for you
    Peter
  • ramguna84
    0 ramguna84 over 11 years ago in reply to Robert Peter Oakes
    Sir,
    This is the demo example code as is from Project#31 of Element14. No Change made, interfaced to check the basic mode of ethernet. Thanks.
    Unfortunately I do not have the PSOC board to test this, there may be another member that could though so be patient and perhaps someone else could advise
    My only advise assuming the original DEMO'S from Project #31 are good it to re-do everything in detail in case you missed something or made a type
    Not saying you did and you may have done this already but I cant think of anything else to suggest at this point
    Peter
  • ramguna84
    Sir,
    I had successfully tested SD card and Ethernet function independently, while merging the functionalists i got few gcc error mentioned below:
    .\main.cpp:261:32: error: invalid conversion from 'unsigned char*' to 'char*' [-fpermissive]
    The command 'arm-none-eabi-gcc.exe' failed with exit code '1'.
    Please suggest me to resolve this errors. I am attaching the build files.
    Ramanathan SG.
    MTech Student
