Ask an Expert Forum Ideas? Detecting a narrow frequency within an audio signal
  • Replies 25 replies
  • Answers 2 answers
  • Subscribers 324 subscribers
  • Views 4061 views
  • microprocessor_controlled
  • bandpass
  • filter
See a helpful answer?
I am looking for a way to detect the presence of a single musical note that lies within a real-world audio signal. For example, from a piano recording, I want to detect when Middle C (440 hz) is sounded while ignoring all the other notes.
Perhaps some kind of tunable bandpass filter would do the job? If so, it would have to be a very narrow bandpass filter because musical notes are separated in frequency by a ratio of about 1.06, which is quite close.
The thing might also be thought of as an AM receiver that operates with a carrier frequency not in the RF but in the audio frequency range.
In my application, the centre (detected) frequency will be controlled by microprocessor. The receiver will frequency-hop, quickly changing the detection frequency. I am imagining that the microprocessor might do this by supplying a clock frequency or by directly writing a digital value.
It does not need to be a precision circuit — simplicity and low cost are more important. The application can tolerate a fair degree of error.
Any ideas?
Thank-you!
Gordon Hicks
    0 Former Member over 11 years ago in reply to Former Member
    Hi William,
    Thanks for the links to the two shields. Perhaps I can find a way to leverage their approach... it's helpful to me in thinking through the problem.
    cheers,
    Gordon
    Detecting a single note digitally can be done without notch filters, by using the Goertzel Algorithm. It's effectively equivalent to calculating a single band of a DFT. It can be performed efficiently in fixed-point math on a microprocessor, too.
    There's a good article on using it to detect DTMF tones here. It should be fairly straightforward to adapt to your needs.
    The Görtzel Algorithm looks like just the thing for my application, thank-you!
  • D_Hersey
    0 D_Hersey over 11 years ago
    Three-op-amp state-variable filter perfects the notch | EDN
  • MicrochipRTCfr
    0 MicrochipRTCfr over 11 years ago in reply to D_Hersey
    For detecting frequencies, DSP based architectures are generally doing much better. In general fixed point DSP units are very efficient for filters.
    As an example dsPIC from the DSC family (Digital Signal Controllers) can implement filters up to the 10th order.
    The free XC16 compiler contains DSP libraries which can be used to implement FIR, IIR or even FFT.
    The IDE is also free (MPLAB X) and runs native on Linux, Mac and windows.
    You may also want to use a specialised SW like Digital Filter Design to fasten your design.
    Regards
