Ask an Expert Forum My new RPi B+ 2 will not boot with mini SD that will boot RPi "A", downloaded updates.  What is the trick?
  • Replies 9 replies
  • Subscribers 307 subscribers
  • Views 919 views
  • frontpage
See a helpful answer?
The updates include apt-get update, apt-get upgrade, apt-get install raspberrypi-ui-mods, and rpi-update  the ls /boot/ lists kernel7.img.  This SD card will still boot in the earlier version RPi A but it does not seem to try to boot the new RPi B+ 2.  What is next?
  • clem57
    clem57 over 10 years ago +1
    Did you overclock the CPU? Remove since different for RPi 2... Really the best is download latest NOOBS or Raspian which should be 2-2-2015 on new SD. I did and mine works great. Clem
    Former Member over 10 years ago in reply to clem57 +1
    Thank you, Clem. I am downloading Raspbian now, and will go that route. I had hoped the B+ would be backward compatible. Thanks, Fred Sent via the Samsung Galaxy S III, an AT&T 4G LTE smartphone
  • Robert Peter Oakes
    Robert Peter Oakes over 10 years ago in reply to clem57 +1
    I am fairly certain it will follow something like the compact framework but updated While I have no expectations it will be as full as the Windows 8 on Surface pro 3 for example, I would expect something…
  • clem57
    0 clem57 over 10 years ago
    Clem
    0 Former Member over 10 years ago in reply to clem57
    Fred
    Sent via the Samsung Galaxy STm III, an AT&T 4G LTE smartphone
    0 Former Member over 10 years ago in reply to Former Member
    Does anyone know where I can find the windows 10 for RP/2?
    0 Robert Peter Oakes over 10 years ago in reply to Former Member
    You won’t be able to simply plug an SD card from the “A” into the PI 2 and back and expect it to work
    You need separate image for each, get a new SD card for the PI 2 and download the new images from Raspberrypi.org and you should be good to go
    0 Former Member over 10 years ago in reply to Robert Peter Oakes
    Thank you Peter, you are correct, that made it work.
    Fred
  • johan825
    0 johan825 over 10 years ago in reply to Former Member
    @Tim Jewell : I do not believe windows 10 is available yet, but more information will be released the coming months.
    You could check : https://dev.windows.com/en-us/featured/raspberrypi2support
    we will be sharing more details about our Windows 10 plans for IoT in the coming months.
    0 Robert Peter Oakes over 10 years ago in reply to johan825
    I don’t believe it is, I am eagerly waiting and often checking
    Peter
  • clem57
    0 clem57 over 10 years ago in reply to Robert Peter Oakes
    Robert Peter Oakes,
      From what I see about Windows 10 does not look like a full Windows environment because of the way the coding may be crippled IMHO. But we will need to wait and see.
    Clem
    0 Robert Peter Oakes over 10 years ago in reply to clem57
    While I have no expectations it will be as full as the Windows 8 on Surface pro 3 for example, I would expect something like that found on an ARM Surface 1 or 2 but with a windows 10 look and feel
    My anticipation is more about being able to code using C# and the .net library and that will be there for sure and supported by the community edition of the Visual Studio IDE
    But to conclude, Yes we will have to wait and see, Speculating can be fun but it is only speculation
    Peter
