Ask an Expert Forum Pi + 2.8 inch screen for portable music player +
  • Subscribers 303 subscribers
  • Views 578 views
  • portable_music_player
See a helpful answer?
I'm trying to play music files through the 3.5mm jack to a headset.  I've tried XBMC but the tft doesn't support it and sends the video to a TV instead.  I've tried VLC and I can see the player playing the file but there's no audio.  Is there any way to set the Pi up to play music playlists?
  • clem57
    0 clem57 over 10 years ago
    Not knowing where or what the screen is, try this image of Rasbian from adafruit: https://learn.adafruit.com/adafruit-pitft-28-inch-resistive-touchscreen-display-raspberry-pi/easy-install Once installed and working, you can download VLC. Which Pi do you have? Are you expecting stereo, I think you need something else like an audio card. You can look at usb sound card also.
    Clem
    0 Former Member over 10 years ago in reply to clem57
    I've tried that image and it does work but VLC has no audio out.  As I said, I can see the player playing the file but there's no audio.  I have the Pi2 and the screen from Adafruit.  Everyone seems to be developing players that work over a network instead of one that is a stand alone functioning completely on the Pi and controlling files on the Pi.
  • clem57
    0 clem57 over 10 years ago in reply to Former Member
    libertygearstore
        It appears volumino may be the way to go based on http://www.tested.com/tech/521750-how-i-turned-raspberry-pi-2-audiophile-music-player/
    Clem
  • clem57
    0 clem57 over 10 years ago in reply to clem57
    http://www.changstar.com/index.php?topic=2181.0
    That's what I'm working on, now.  It too, is controlled over a network but I found an article where a guy has made it work on its own browser.  I've tried to duplicate what he's done but it's not working.  If I knew more programming, I'd just create a player that works.
