Ask an Expert Forum Hi People.  HELP>>>
  • Subscribers 301 subscribers
  • Views 1746 views
  • ecb problems
See a helpful answer?
Hi People.  HELP>>>
shanebeattie
shanebeattie over 4 years ago
QUESTION  Hi  People,,  I am trying to repair ECB and i can't find a couple of parts made in japan  CB1a-P-12V   ACB 33102  71226M  2616 on the first and the second has the same header and 80325M  2517..  I think they are some sort of soldered in relay, can any one help please.
    0 Jan Cumps over 4 years ago
    CB1a-P-12V   ACB 33102  71226M  2616, the same header and 80325M  2517
    It's a 4 pin automotive relay of Panasonic/NAIS. Model ACB33102 CB1a-P-12V
    Here's an image of the 24 V version (does not work for you. You need to find the 12 V version, maybe this one from Farnell - check availability?):
    image source https://nl.aliexpress.com/item/1005001579286753.html
    This datasheet of the CB family has a translation from codes to parameters: https://www.farnell.com/datasheets/1972629.pdf
    Your first one: CB1a-P-12V
    1a: FORM A
    P: PC Board type
    12V: Coil voltage (DC) 12 V
    Standard type, No diode or resistor, normal heat, no high current or contact capacity, sealed
    2616, 2517
    My guess that the first one is made week 26, 2016 and the second one week 25, 2017.
  • colporteur
    0 colporteur over 4 years ago in reply to Jan Cumps
    Great find JC. So where do you store all your manualsimage?
    0 Jan Cumps over 4 years ago in reply to colporteur
    I worked for an automotive company in my younger days image. This one. Then.
