Ask an Expert Forum Digital LED Counter Wiring for Thru Beam Sensor
  • Subscribers 338 subscribers
  • Views 1031 views
  • experts
  • ask_an_expert
  • circuit
  • sensor
See a helpful answer?
Rahatanwar10
Rahatanwar10 over 4 years ago
I recently bought a Reflective Infra Red Sensor and a Digital LED Counter for a packaging line. I wanted to know if I can wire a thru beam sensor on the same counter as that would fit the packaging line better.
Attached on this post are images of the Digital Counter circuit, 4 wires(Thru Beam Sensor), Sensor. Can this digital counter can accommodate the sensor ? Any help or suggestion would be great..
The goal of the counter is to count items. FYI, I am a novice with electronics and wiring
  • beacon_dave
    beacon_dave over 4 years ago
    If in doubt, refer to the documentation.
    literature.rockwellautomation.com/.../42jsjt-td001_-en-p.pdf
    Looks like you are holding the emitter module there.
    product details from manufacturer's spec sheet
    which will require a 10-30V DC supply.
    manufacturer's wiring diagram for emitter module
