Ask an Expert Forum Problem regarding MOSFET
  • Subscribers 337 subscribers
  • Views 1513 views
See a helpful answer?
Nigella
Nigella over 4 years ago
I have generated PWM through SG3525 IC and then I have given its output to IR2110 to make it a 12-volt PWM by which I am driving MOSFET (IRF540) at a 10 to 40% duty cycle. when I place CHOPPER at the source of this MOSFET then MOSFET gets too heated.
(drain voltage for MOSFET is 12 to 17 voltage)
Without placing a chopper it's working fine but with a chopper it gets heated...
Can anyone guide me on why MOSFET(IRF540) is getting heat???
I would be highly thankful to you people...
    Jan Cumps over 4 years ago +1
    what does your circuit, with and without chopper, look like?
    dougw over 4 years ago +1
    Typically MOSFETs will get hot if they don't get fully turned on or if the switching time is too long. This FET requires about 7 volts at the gate to fully turn on. Make sure your chopper output is switching…
    This FET requires about 7 volts at the gate to fully turn on. Make sure your chopper output is switching quickly and it is getting to 7 volts.
    This FET has a gate capacitance of 1700 pf so it may require a high current driver to get it to switch quickly.
    AT heavy loads this FET will likely need a heatsink, mostly because of switching losses.
