Ask an Expert Forum Trying to understand serial to parallel circuit
  • Replies 32 replies
  • Subscribers 337 subscribers
  • Views 10803 views
See a helpful answer?
opalko
opalko over 4 years ago
Hi again folks (after some time away!),
When I was a teen, I had an Atari 800 computer/ The Atari did not have a parallel port interface.  All they had were the joystick ports, which were serial.  A clever company came up with a serial->parallel port interface.  Me, not knowing much about electronics, could not figure out how they did this.  (PS -I still don't know much about electronics!!!).
Flash forward 40 years and this past week I decided to take apart the serial->parallel interface and reverse engineer this thing! I took apart and there are 2 chips - a 74LS14, and a 74LS164, a resistor and a capacitor. Next step was to draw the schematic, which I did with pencil and paper. This became messy, so I resorted to learning to use KiCad, and came up with the attached drawing. (see attachments)
I get what makes this work is the 74LS164 8 bit parallel-out serial shift register. I still don't really understand how it works though.  As I understand it, the data on this register may be read out in parallel (from all flip-flops) at once.
So some questions!
0) Can someone explain how this whole interface works!?
1) How is the data being read on the printer side?  Is the printer polling every data pin on the parallel port at once regardless of how many are actually being used?
2) Since there are really only 2 address data pins (3 & 5) being used here, it doesn't seem a vast improvement over serial?  But I guess because the Atari only has pins 1-4 for I/O and 1 of those sends the data to the 74LS164?
Thanks for any help understanding this.
Robert Opalko
PS There doesn't seem to be nearly as many members on this forum as there was in the past... Where did everyone go?
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to opalko +4
    try this link: computer.howstuffworks.com/parallel-port1.htm this says that IBM did it but in fact, It was Wang labs. and en.wikipedia.org/.../Centronics
  • phoenixcomm
    phoenixcomm over 4 years ago +4
    dougw over 4 years ago +3
    I don't get it either. A Centronics printer needs 8 data bits and some handshaking to work - this doesn't even have enough pins connected. On a Centronics connector all pins from 19-30 and 33 are ground…
  • airbornesurfer
    0 airbornesurfer over 4 years ago in reply to beacon_dave
    Ha! I'll throw it on the list ;)
    I still gotta finish that record player, first....
  • beacon_dave
    0 beacon_dave over 4 years ago in reply to opalko
    opalko said:
    If I can get a program to just read my keypress and sending it out the Centronics side I will be thrilled...
    It looks like 'INPUT' and 'LPRINT' keywords in a loop in  Atari BASIC could perhaps get you most of the way there ?
    Atari BASIC keywords:
    https://en.wikipedia.org/wiki/Atari_BASIC#Keywords
    The Atari 820 printer operators manual shows:
    10 PRINT "THE PRINT COMMAND COMES OUT HERE."
    20 LPRINT "THE LPRINT COMMAND COMES OUT HERE."
    as an example of sending text to the console and then to the printer. Just remember that the select and busy inputs will require to be set correctly to get the data to flow, as you won't have a physical printer connected.
