Ask an Expert Forum Trying to understand serial to parallel circuit
  • Replies 32 replies
  • Subscribers 337 subscribers
  • Views 10802 views
See a helpful answer?
opalko
opalko over 4 years ago
Hi again folks (after some time away!),
When I was a teen, I had an Atari 800 computer/ The Atari did not have a parallel port interface.  All they had were the joystick ports, which were serial.  A clever company came up with a serial->parallel port interface.  Me, not knowing much about electronics, could not figure out how they did this.  (PS -I still don't know much about electronics!!!).
Flash forward 40 years and this past week I decided to take apart the serial->parallel interface and reverse engineer this thing! I took apart and there are 2 chips - a 74LS14, and a 74LS164, a resistor and a capacitor. Next step was to draw the schematic, which I did with pencil and paper. This became messy, so I resorted to learning to use KiCad, and came up with the attached drawing. (see attachments)
I get what makes this work is the 74LS164 8 bit parallel-out serial shift register. I still don't really understand how it works though.  As I understand it, the data on this register may be read out in parallel (from all flip-flops) at once.
So some questions!
0) Can someone explain how this whole interface works!?
1) How is the data being read on the printer side?  Is the printer polling every data pin on the parallel port at once regardless of how many are actually being used?
2) Since there are really only 2 address data pins (3 & 5) being used here, it doesn't seem a vast improvement over serial?  But I guess because the Atari only has pins 1-4 for I/O and 1 of those sends the data to the 74LS164?
Thanks for any help understanding this.
Robert Opalko
PS There doesn't seem to be nearly as many members on this forum as there was in the past... Where did everyone go?
  • phoenixcomm
    phoenixcomm over 4 years ago in reply to opalko +4
    try this link: computer.howstuffworks.com/parallel-port1.htm this says that IBM did it but in fact, It was Wang labs. and en.wikipedia.org/.../Centronics
  • phoenixcomm
    phoenixcomm over 4 years ago +4
    dougw over 4 years ago +3
    I don't get it either. A Centronics printer needs 8 data bits and some handshaking to work - this doesn't even have enough pins connected. On a Centronics connector all pins from 19-30 and 33 are ground…
  • opalko
    0 opalko over 4 years ago in reply to beacon_dave
    Was away for a few days doing DIY for granite countertop install running new wiring to cooktop & reconnecting plumbing...ugh...
    Ok I think I have it correct now (hope so or this will be embarrassing!)
  • opalko
    So now that I understand the numbering system for the ribbon to PCB, I am wondering what the soldering on the Centronics pins 17, 20, and 36 (the three corner pins) are for since they are not connected to any traces.  Are these just solders just for a mechanical connection?
  • opalko
    This was great - thanks!
  • opalko
    Cool thanks for that explanation!
  • beacon_dave
    0 beacon_dave over 4 years ago in reply to opalko
    Most likely to hold the component in place during assembly. It is common to solder the corner pins of components first to hold them in place flat against the PCB, before you go on to solder the rest. Otherwise it is difficult to fix afterwards if you reach the end of the row and find something moved earlier on. Especially in this case where you are 'fighting' against a springy ribbon cable that wants to do its own thing.
  • beacon_dave
    Also perhaps take a look at makerkaren 's follow-up hands-on video:
    How to Make a 4-bit Shift Register Circuit
    /challenges-projects/element14-presents/thelearningcircuit/w/documents/4970/the-learning-circuit-76-how-to-make-a-4-bit-shift-register-circuit
    to help reinforce your understanding.
    You could also perhaps simulate your design on the likes of Tinkercad to help reinforce your understanding of it:
    Tinkercad
    https://www.tinkercad.com/learn/circuits
    and finally go on to build a simulation for real using the likes of an Arduino to send serial data into your MPP-1100 interface and then capture the output of it and display the result on the serial terminal.
    Then post a blog about it here on the Element14 community.
  • opalko
    Going over to watch that video now! I like those other ideas as well. What got me started on this was buying an old Science Fair Microcomputer Trainer that has a 4 bit CPU and a 4x5 matrix "keyboard" to enter assembly language programs into it. Entering programs is a drag and I thought I could use this parallel circuit to enter programs from the Atari into it.  Not sure this would work now and I think I would need 2 shift registers to read the keyboard matrix input.....
    Going to check out tinkercad also!
  • beacon_dave
    A sort of 'print your code' into the trainer type approach ?
    Sounds doable but it could turn into a bit of  'a long way around for a shortcut' type scenario. Depends on the motivation and if there is any specific 'emotional attachment' to the Science Fair trainer.
    FYI it looks like someone on Instructables created an emulator which may be of interest if you just want to be able to run the programs from the trainer kit manual:
    Radio Shack Microcomputer Trainer Emulator in Scratch
    https://www.instructables.com/Radio-Shack-Microcomputer-Trainer-Emulator-in-Scra/
    If you still want to use the Atari printer utility then remember that you will likely get ASCII character values out of the Centronics end if you are printing from a text editor. For example if you print the character '1' then that is going to be treated as a value of 31hex and appear as 00110001 on the Centronics data bus. You will likely need to use the strobe signal to simulate the actual key press and you will also need to take care of the select/busy inputs to keep the Atari happy, and if necessary to slow down the data rate into the trainer, which is expecting slow human keypresses.
    You may find that the likes of an Arduino is an easier route as you have more control over the GPIO pins for simulating the keyboard matrix input.
  • opalko
    Yeah, now that I have written it out, it sounds like a goofy idea..
    Cool
    If I can get a program to just read my keypress and sending it out the Centronics side I will be thrilled...lol. Thanks for the extra info
  • beacon_dave
    From what I saw, the MPP-1100 appeared to be able to make use of the ROM update to support the Atari 850 interface module.
    Atari 850 Interface Module
    http://www.computinghistory.org.uk/det/52934/Atari-850-Interface-Module/
    So software designed to use the parallel port output port of the 850 module, appears to also work with the MPP-1100 interface.
    However, programming the Atari Serial IO System port directly, would likely give you more flexibility.
    One for  airbornesurfer  perhaps ?
