    • Avnet Boards Community
Ask an Expert Forum Triac 0-10V control
  • Replies 11 replies
  • Subscribers 289 subscribers
  • Views 3288 views
See a helpful answer?
Triac 0-10V control
Pips
Pips over 3 years ago
The goal is to control thru a triac a low power 24VAC load, by a 0-10VDC setpoint
Generating a synchronizied ramp and zero crossing detection, comparating and firing the triac is well known.
BUT : is somebody knowing an IC to do that (the goal is space saving) ?
Thank you for your ideas
  • colporteur
    colporteur over 3 years ago +2 verified
    https://www.banggood.com/One-way-Solid-State-Relay-Module-p-979853.html?cur_warehouse=CN https://www.banggood.com/Two-way-Solid-State-Relay-Module-p-979855.html?cur_warehouse=CN https://www.banggood…
  • kkazem
    kkazem over 3 years ago +2
    There are numerous ICs for controlling triacs, typically divided into Zero-crosssing vs non-zero crossing types. Do a Google search for triac control IC.
  • colporteur
    colporteur over 3 years ago in reply to Pips +1
    The terms used added some confusion. You are looking to regulate the AC voltage using a triac? There is a difference between regulate and control. Maybe provide some description of the goal of…
  • Pips
    0 Pips over 3 years ago in reply to colporteur
    Hello Colporteur,
    You are right : it's the first time I'm trying to get an answer using a forum !
    And you are right again : a little drawing will help ....image
    So ... the basic question was : does somebody knows if there is a supplier who has integrated the red surounded part of this simplified schematic (or similar function, or a part of it, ...) in a DIL6 ?
    The T2 - T1 stage is the synchronized ramp building, the comparator is ... comparing, with the DC set-point, and the UJT stage firing the thyristor.
    It is simple intelectual curiosity
    Actually I'm firing the thyristor trough a pulse transformer, because I don't like the link between neutral and DC power zero, and some other implementation reasons.
    Thank you again for your patience, and sorry for my poor english, I don't trust translating softwares ...
    Best wishes
    Piper
