Ask an Expert Forum Wifi signal booster
  • Subscribers 304 subscribers
  • Views 1150 views
See a helpful answer?
Wifi signal booster
manojroy123
manojroy123 over 3 years ago
I am looking for wifi signal booster circuit at least 36 db gain or more can any one help me with the circuit
    shabaz over 3 years ago +1
    To me the question doesn't make sense, but it's better if you try to work it out, into a very basic specification of what you'd like the circuit to do (consider input and output signals and their levels…
  • a531016
    a531016 over 3 years ago +1
    This is a bit of a tricky one - if you are after amplifying the signal before the antenna, you could well fall foul of location laws and regulations. Most consumer RF equipment is power limited to prevent…
    To me the question doesn't make sense, but it's better if you try to work it out, into a very basic specification of what you'd like the circuit to do (consider input and output signals and their levels), and in the process you may either make me see sense, or you may come around to also agreeing it doesn't make sense either.
    Basically, consider what you wish the circuit to do precisely, then consider the input signal level and then add 36 dB to it, and determine the power in watts.
  • a531016
    This is a bit of a tricky one - if you are after amplifying the signal before the antenna, you could well fall foul of location laws and regulations. Most consumer RF equipment is power limited to prevent interference to others using the same or similar frequencies.
    If you are after a physical modification to the antenna to increase the gain, this may be possible, but there is a lot to consider to achieve what you need? As shabas says, providing more detail on your problem would help us answer you?
