Ask an Expert Forum Irrigation system based on RF valves - can it be done?
  • Subscribers 303 subscribers
  • Views 1810 views
  • project
  • raspberry pi
  • sprinkler
See a helpful answer?
funkymonkey
funkymonkey over 3 years ago
Hi all,
I'm looking at creating a zoned irrigation system for my garden where RF-valves can be run off a main water feed that runs around the garden.  Essentially a main box would send signals to each valve as it is needed to water a flowerbed.  Is anyone aware of RF battery operated valves that I might be able to integrate with Arduino or a Pi.  I have seen solutions using relay boards, but I am trying to see if there is a way I can do it without needing to run power cables all around the garden.  I am almost thinking of something like the Honeywell Evohome radiator valves but that will be waterproof.  Something that is truly wireless.  I would consider a wi-fi solution, but would prefer RF.
Many thanks for any pointers to RF valve solutions and transmitters anyone can offer!
Duncan
    shabaz over 3 years ago +1
    Hi Duncan, This sounds like a reasonable approach, it may work. You may find that (say) the valve doesn't fully open since they are not designed for high flow rates, but maybe that's not an issue, I…
    0 shabaz over 3 years ago
    Hi Duncan,
    This sounds like a reasonable approach, it may work. You may find that (say) the valve doesn't fully open since they are not designed for high flow rates, but maybe that's not an issue, I don't know. It would need testing.
    A search reveals there are DC power operated latching solenoid valves for water on AliExpress, some intended for irrigation, and at a similar cost to the radiator valve method but they don't contain the wireless functionality etc, so for an almost ready-made but low-cost option, your idea could work.
    By chance I have some MiHome battery-operated devices intended for connecting on top of thermostatic radiator valves (TRVs) so I could give it a shot at some point too, but probably not for a week or so. Weather extremes might cause issues with rubber seals etc, but I don't know. Some things not intended for outdoor use can still work remarkably well provided there is some basic shielding from elements.. some things will fail though.
    There are also battery-operated cistern/WC flush valves, that are very cheap on Aliexpress, but again they would require the wireless functionality to be added on.
  • funkymonkey
    0 funkymonkey over 3 years ago in reply to shabaz
    Thanks I had tried Alibaba, but AliExpress.  Will see what I can find.  Might have to look at modding if I cannot find anything.  If I thought I could hack the RF signals on the radiator units I would try adapting one of those.
