Ask an Expert Forum LED speed of response
  • Subscribers 338 subscribers
  • Views 1144 views
See a helpful answer?
Deke
Deke over 3 years ago
What would be the maximum speed that a bog standard LED can switch on and off at regardless of the transistor used. Would the colour of the LED make a difference (I'm presuming it might).
Thanks.
    shabaz over 3 years ago +1
    Hi, It's likely in the tens of MHz, since this Hamamatsu red LED provides operation at 70 MHz: https://www.hamamatsu.com/eu/en/product/light-and-radiation-sources/led/L10762.html LEDs with phosphors…
    dougw over 3 years ago +1
    LEDs can switch in nanoseconds, but with garden variety circuitry it gets problematic to achieve much more than 1 MHz operation. IR LEDs are generally faster than visible LEDs.
    0 shabaz over 3 years ago
    LEDs with phosphors (e.g. white LEDs) may have a slower response time. Size of LED and how it's driven (e.g. keeping it on the edge of switching on) may make a difference.
    Most standard (visible) LEDs that are for indicator purposes probably won't have a specification for this however, since it's not their normal use-case, so it may need experimentation if you wish to find particularly fast ones for instance.
  • Deke
    0 Deke over 3 years ago in reply to shabaz
    Thanks very much for this. It's just general info for an idea...
    0 dougw over 3 years ago
