Ask an Expert Forum Lung monitor
  • Subscribers 305 subscribers
  • Views 634 views
See a helpful answer?
Lung monitor
Himanshu
Himanshu over 3 years ago
 Which sensor will be best for lung monitor
  • ralphjy
    ralphjy over 3 years ago +3
    The monitor that is commonly used in hospitals to estimate oxygen saturation in the blood is the pulse oximeter. It usually clips onto your fingertip and uses LEDs and photodiodes to measure oxygenation…
    genebren over 3 years ago +3
    If you are referring to monitoring lung capacity, then you are likely looking for a spirometry sensor. These are typically differential pressure sensors.
  • ralphjy
    The monitor that is commonly used in hospitals to estimate oxygen saturation in the blood is the pulse oximeter.  It usually clips onto your fingertip and uses LEDs and photodiodes to measure oxygenation in the blood.  Here's a good explanation pulse-oximetry-basic-principles-and-interpretation.  This can give you a quick estimate of lung and blood circulation performance.
    You can buy assembled units - one that I've used Innovo-Fingertip-Oximeter-Plethysmograph-Perfusion.  Or if you wanted to build your own there are also sensor boards available.  One that uses the MAX30100 - MAX30100-Oximeters-Development-Assistant-Monitoring.
