    About Us
    • Watt's Up?
Ask an Expert Forum Short distance high speed wired communication options?
  • Replies 8 replies
  • Subscribers 315 subscribers
  • Views 1671 views
  • Shortrangecommunication
See a helpful answer?
Srin
Srin over 3 years ago
        Just looking at options available for two wired 30-40m distance communication upto data rates of 15MBps? Can we have a detailed discussion on the available options.
Thanks.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago +3
    The only solution that comes to mind is single pair ethernet.
  • colporteur
    colporteur over 3 years ago +3
    /learn/publications/ebooks/w/documents/27790/fundamentals-of-single-pair-ethernet---ebook There is an ebook available on SPE that might provide some insight. /technologies/connector/w/documents/23123…
  • BigG
    BigG over 3 years ago +2
    Similar to Ethernet based solution but using power lines... www.tp-link.com/.../
  • wolfgangfriedrich
  • BigG
    dougw over 3 years ago
    It isn't exactly wire but a fiber optic ethernet link might also work.
    If you need a simpler protocol, you could run RS-485 over fiber. (because the wired version of RS-485 can't go that far at that speed)
    shabaz over 3 years ago
    It would also help to know precisely what the use-case is. It sounds odd to want such a data rate for this type of distance. It's not clear if the communication needs to support both directions, and whether what you're transmitting can support error-handling, or if you expect that to be supported by a lower-layer.
    What is the use-case?
    michaelkellett over 3 years ago
    Strange, I replied to this yesterday but the reply has vanished.
    I suggested that you need to provide a good deal more information about the context because that will drive the solution.
    For PC - PC communciations (or SBC to SBC) then standard Gbit Ethernet is the obvious answer.
    If it's FPGA - FPGA then LVDS would be possible.
    Several of the answers you have had already seem to have missed that you want 120 Mbps, but untill you define other things a good answer is not possible.
  • colporteur
    /technologies/connector/w/documents/23123/single-pair-ethernet-quiz?ICID=connector
    this was a SPE quiz offered a while ago.
    /technologies/connector/w/documents/23242/single-pair-ethernet-quiz-resource
    and the resources for it.
  • beacon_dave
    beacon_dave over 3 years ago in reply to dougw
    Or if you can't decide between fiber and wire... Slight smile
    https://youtu.be/rQKx2nwiVyQ?t=159
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to colporteur
    Thanks for posting the links. I had those in mind when suggesting SPE.
