Ask an Expert Forum Fuse
  • Replies 9 replies
  • Subscribers 302 subscribers
  • Views 1665 views
See a helpful answer?
Fuse
ersler
ersler over 3 years ago
Hi!   I need  a fuse  8A 250VAC RAD 373.  I was not able to find any.  I am i Thailand.  I need to buy this online with shipping to Thailand. Can you please help me. Thank you
  • Gough Lui
    Gough Lui over 3 years ago in reply to rscasny +2
    Generally speaking, if it is for replacement, you should never use a fuse with a rating higher than the original as this would potentially create safety issues (e.g. fire, excessive downstream damage in…
  • Gough Lui
    Gough Lui over 3 years ago in reply to ersler +2
    That looks to me to be a Fast-blow type (hence F 8A, rather than T 8A). I didn't see any on element14 to be of the right value - the only 8A units seem to be time delay / slow-blow types which would…
    michaelkellett over 3 years ago +1
    Since you don't say where you are it's a little hard to help. Mouser have them: MK
    Mouser have them:
  • cstanton
    cstanton over 3 years ago
    You should be able to find a bunch on Farnell / element14 / Newark
    Here's an example search:
  • rscasny
    rscasny over 3 years ago
    Can you use a 10A fuse:
    www.newark.com/.../67K2010
    michaelkellett over 3 years ago in reply to rscasny
    I saw that Farnell didn't have the 8A part  - I wouldn't have suggested the opposition otherwise Relaxed
  • ersler
    ersler over 3 years ago in reply to rscasny
    There is 2.5A on the picture
  • Gough Lui
    Generally speaking, if it is for replacement, you should never use a fuse with a rating higher than the original as this would potentially create safety issues (e.g. fire, excessive downstream damage in case of fault).
    Using a lower value may be permissible but is likely to lead to nuisance fuse blowing.
    You should also match the fuse time characteristics - some are quick/fast-blow and others are slow-blow/time-delay types. Using a fast blow type may lead to nuisance blowing in case of in-rush. Using a slow-blow type may fail to protect sensitive circuits.
    Always best to make sure you have the complete part number and decode it as to its characteristics ... then search for a replacement. It doesn't necessarily have to be the same brand, as long as the size, voltage, current, time-characteristics are the same and the breaking capacity is equal or greater, then it should perform as per the original and maintain safety.
    - Gough
  • ersler
    ersler over 3 years ago in reply to Gough Lui
    Jan Cumps over 3 years ago in reply to ersler
    The picture will be the same for all fuses in that same product range. Check the parameters to the right for the actual currency.
  • Gough Lui
    I didn't see any on element14 to be of the right value - the only 8A units seem to be time delay / slow-blow types which would not have the same response speed.
    - Gough
