Ask an Expert Forum Multicomp Pro MP750289 Signal Generator Waveform CD's USB driver
  • Replies 14 replies
  • Subscribers 338 subscribers
  • Views 4344 views
See a helpful answer?
richardsonpj
richardsonpj over 3 years ago
The Multicomp Pro MP750289 Signal Generator Waveform CD's USB driver installation instructions do not work.
I thought i found the USB files that were misidentified as "Program Files (x86)\DSO\USB_DRV\win10_win8_win7_vista" in "\Program Files (x86)\DS_Wave\Waveform Editor\USBDRV\win10_win8_win7_vista", but they aren't working, even after trying "install.bat", "reinstall.bat." or directly entering the instructions in the readme files.
Searches have been ineffective.
    Jan Cumps over 3 years ago in reply to dougw +3
    The Zadig utility may help to get a good driver installed. If the device is expecting a serial or winusb driver, Zadig usually gets the job done.
  • ralphjy
    ralphjy over 3 years ago in reply to rsjawale24 +2
    I have an MP720016 and I didn't have any issues getting it to work with USB. It is also powered by the USB connection.
  • baldengineer
    baldengineer over 3 years ago +1
    FWIW, I tried getting them to work about a year ago. But I never got the USB drivers to work either. I remember getting them installed, but neither my computer nor the AWG ever acknowledged the connection…
  • baldengineer
    0 baldengineer over 3 years ago
    FWIW, I tried getting them to work about a year ago. But I never got the USB drivers to work either. I remember getting them installed, but neither my computer nor the AWG ever acknowledged the connection. At the time, I decided it must be a faulty USB interface.
    I ended up using LAN instead.
  • rsjawale24
    0 rsjawale24 over 3 years ago in reply to baldengineer
     I just ordered the Multicomp USB oscilloscope as the prize for project 14. But now I'm scared if it will be detected in my PC or not.
  • richardsonpj
    0 richardsonpj over 3 years ago in reply to baldengineer
    The LAN version is working?  I will need to get another drop or a hub (and register it), but i didn't want to do it before i tested the interface with USB.  They charge us to install either.
  • baldengineer
    +1 baldengineer over 3 years ago in reply to richardsonpj
    I don't know what your situation is, but even a USB-to-Ethernet adapter with a cross-over cable works fine.
  • richardsonpj
    Thank you!  I can get one, i just wanted to check it first.  Thanks!
  • baldengineer
    0 baldengineer over 3 years ago in reply to richardsonpj
    Just to be clear, you'll still be interfacing over Ethernet, not USB. You'll need to setup a private network between your computer and AWG. e.g., give the Ethernet-to-USB adapter an IP like 10.0.0.1 and the AWG an IP like 10.0.0.2.
    Then through VISA (or whatever) you'll connect to the AWG as TCPIP::10.0.0.2, instead of USB.
  • ralphjy
    0 ralphjy over 3 years ago in reply to rsjawale24
  • rsjawale24
    0 rsjawale24 over 3 years ago in reply to ralphjy
    Thanks! I can't wait to try out my first ever scope! Really excited for it Slight smile
    0 dougw over 3 years ago in reply to baldengineer
    It appears to be the wrong drivers. I have the same problem and Windows indicates the drivers supplied are not for this device. Perhaps the Multicomp rebranding exercise missed something. Quite disappointing since there doesn't seem to be much recourse for support of Muticomp.
  • baldengineer
    0 baldengineer over 3 years ago in reply to dougw
    In my case, I do not believe it was a driver issue. Ultimately, I realized neither Windows nor Linux would attempt to enumerate the device when attached.
