Ask an Expert Forum PNBC006 WENGLOR DISTANCE LASER SENSOR RPi interfacing trouble
  • Replies 21 replies
  • Subscribers 336 subscribers
  • Views 5431 views
See a helpful answer?
AZ87
AZ87 over 3 years ago
Anybody has an idea on how to read the measurements made by an industrial sensor using a raspberry pi??? I've already posted the same question somewhere in the forum but did not get any answer, so i thought Ive posted in the wrong place and here I am; first of all please don't judge me and HATE me if my question may sound ridiculous to you, i am a complete newbie to this field: i need to get the readings of this sensor through rasberry Pi and i have no clue; it is a  Wenglor PNBC006 Laser Distance Sensor and after many many days hunting on the web, i came across some documentation stating that this industrial sensor supports 2 type of connections: an M12 8pin cable AND an Ethernet cable. I figured out i can just connect it through an industrial Ethernet switch and make the communication with raspberry pi through the ETHERNET plug on it; from the official docs of Wenglor I can access the sensor settings and configuration panel through the IP address (which is provided) with a normal browser. My dilemma and biggest trouble is HOW DO I READ THE VALUES OF THE SENSOR WITH RASPBERRY PI? PLEASE HELP ME OR POIT IN THE RUGHT DIRECTION
MQNY THANKS Pray tone5
    shabaz over 3 years ago +1
    Hi, You've double-posted, once in "EAGLE CAD" which makes no sense. That sensor cannot interface directly to the Raspberry Pi. The sensor has an analog interface, and the Pi doesn't. You mention…
  • mp2100
    mp2100 over 3 years ago +1
    This device appears to work best with a PLC. Programable Logic Controller. The documents specifically mention Siemens PLC. Step7 or TIA Portal. The device outputs 4 to 20 mA. The industry standard for…
  • beacon_dave
    beacon_dave over 3 years ago in reply to shabaz +1
    It looks like if you connect to TCP port 3000 instead of the web server, then you can get a continuous data stream. For monitoring they appear to recommend using their wTeach software over the web…
    0 shabaz over 3 years ago
    You mention using Ethernet, and it has a web server, so you can open up a web browser on any PC (doesn't have to be a Raspberry Pi for your initial test, it makes no difference) and observe the sensed value, but it will likely update at a much slower rate that way, so you may be waiting forever to scan the tire width that way.
    For the analog interface (which is your only real choice if you want a practical speed) you'll need a converter, for instance this device (I've not used it): ncd.io/.../
    You'll also need to write some code or look for demo code for whichever specific 4-20 mA receiver you use, hopefully the manufacturers of those will provide you with some sample code.
  • mp2100
    0 mp2100 over 3 years ago
    This device appears to work best with a PLC. Programable Logic Controller. The documents specifically mention Siemens PLC. Step7 or TIA Portal. The device outputs 4 to 20 mA. The industry standard for PLCs. It can also send ethernet data through its m12 port, which is an industrial ethernet connector. But not for a raspberry pi.
  • AZ87
    0 AZ87 over 3 years ago in reply to shabaz
    Pray tone5Pray tone5Pray tone5Pray tone5 I'll try this thank you so much, i would never been able to figure this out EVER
  • beacon_dave
    0 beacon_dave over 3 years ago in reply to shabaz
    For monitoring they appear to recommend using their wTeach software over the web browser, which I suspect also connects over port 3000.
  • beacon_dave
    +1 beacon_dave over 3 years ago in reply to mp2100
    Sounds like it uses a 100Mbps Ethernet connection just with a rugged connector.
    So just need the appropriate RJ45 adapter cable ?
    If the OP is already connecting to it via a web browser, then I think they have established connectivity however. Slight smile
  • AZ87
    0 AZ87 over 3 years ago in reply to beacon_dave
    First of all thank you very much for your input beacon_dave  ; Infact i  managed to connect it to access the config/settings through the web browser and i also can see the readings; the question is how do I get those readings controlled by let say a python script using RPi? Any help would be appreciated
  • beacon_dave
    0 beacon_dave over 3 years ago in reply to AZ87
    The Raspberry Pi Foundation created a free course on this area which might be a good starting point ?
    Networking with Python: Socket Programming for Communication
    https://www.futurelearn.com/courses/networking-with-python-socket-programming-for-communication
    0 shabaz over 3 years ago in reply to beacon_dave
    Well-spotted! I missed that.
  • colporteur
    +1 colporteur over 3 years ago in reply to AZ87
    Careful you getting dangerously close to the edge of doing something you didn't think you were capable of doing.
    I think this is a great project to get your feet wet. If it is something you like doing. The folks that hang out here are a great resource as you may have discovered.
    I suggest you frame how what you think needs to be done and then identify your knowledge level. Let's try and avoid it being overly complicated this first time. It will take some time to work through but I believe it is doable.
    • Vote Up -1 Vote Down
  • AZ87
    0 AZ87 over 3 years ago in reply to colporteur
    Hi there, thank you for the input colporteur  as i mentioned previously I managed to access the web portal of the sensor where I can actually play with the values&settings& configurations...and it is all done through the IP address which is assigned to the sensor by the company itself. So for this i just needed a normal Ethernet connection and access the IP address with a normal browser. Till here worked just fine.
    Now, the real challenge and REAL TROUBLE for me at least, is  getting  those sensor readings interact with raspberry pi, i mean I have the need manage those reading in such a way that I can write down a python script using the readings values: and here I'm completely lost.
    I was thinking of actually phisically attach wires to M12 8 pin cable in such a way that i would reproduce this type of schematic: from my understanding it should work and if it doesn't the i really surrender, it has been a wild wild wild ride of frustration not being able to figure out how to interface the sensor with Pi; here is what I'm trying to do:
    This is the actual https://electronics.stackexchange.com/questions/394248/how-to-connect-an-industrial-24v-sensor-to-a-3-3v-input-raspberry-pi-pin
    If you read through, the guy of this schematics intends reduce the 24V of the sensor Output to a 3.3V signal ant then feed it to the Pi: this is roughly my idea and I'm planning to do it with an octocoupler! OBVIOUSLY I AM OPEN TO ANY HELP OR SUGGESTIONS AS TO DO THIS OR ANYTHING ELSE THAT ALLOW TO get readings into the Pi
