Ask an Expert Forum makevode smartcity extension
  • Subscribers 326 subscribers
  • Views 778 views
See a helpful answer?
naimlion
naimlion over 3 years ago
hi all.i have iot bit 1.6 ,so when  i use smartcity extension in makecode i can´t connect to wifi.help please.so i use this extension because it conains blocs to read data from thingspeak channel.
if i use iot environnment extension i connect to wifi and there´s no pb but this extension don´t contain bloc to read from thingspeak
help and thx in advance
i share you my screenshot of the issue
best regards
  • naimlion
    shabaz over 3 years ago
    The right-side of the code is chopped off in your photo. Also, the blocks are supposed to be connected surely? They all look separated, so it won't work.
    If the blocks cannot connect then what you're doing is not supported or you need to find blocks that do connect.
    You might need to write in more detail, and explain if this extension normally works with WiFi or not, so people can see if what you're doing is supposed to be supported or not.If this smartcity extension has any ready-made examples, do they work? If they work, then you can look at the difference between what you're doing and what the example did, to try to narrow down on the problem.
  • naimlion
    naimlion over 3 years ago in reply to shabaz
    thx ,so this extension works with smarthon and not with my iot bit.so i used elecfreaks iot environnment extension all works well and i connect to wifi and to thingspeak but the problem is always exist because this extension don't contain blocks to read data feeds from thingspeak.so i created my custom extension on github but always i don't succeed to read from thingspeak. here the link of my custom extension
    https://github.com/naim514/esp8266_iot_naim
    help please
    i'm eager to read with my poor iot bit 1.6 version from thingspeak so to remote control my led .on the way this is the second method to try ,because using the first method by mqtt i succeed to remote control my led
    yours trully
    naim computer science engineer and robotic teacher from tunisia
