Ask an Expert Forum Need help sourcing replacement navigation switch
  • Replies 9 replies
  • Answers 3 answers
  • Subscribers 323 subscribers
  • Views 2023 views
  • navigation switch
  • sony fs5
See a helpful answer?
cstanton
cstanton over 3 years ago
Can you find this 4 position miniature navigation switch from a Sony FS5 grip,  It has three contacts this side and three on the back, and four ground plane points on the other adjacent sides.
This's all the information I have from a friend who needs a drop-in like for like replacement.
  • Gough Lui
    Gough Lui over 3 years ago +5 verified
    Found an AliExpress seller offering the whole flex assembly. No idea why my phone always loads their Arabic page though - m.ar.aliexpress.com/.../1005003682915052.html Doesn't seem to give me much…
    shabaz over 3 years ago +2 suggested
    Might be hard finding an exact replacement! On aliexpress there are quite a few with three pins on each side so they might be compatible but no idea if the peg at the top would fit or could be modified…
  • Gough Lui
    Gough Lui over 3 years ago +2 suggested
    We really need measurements, close-ups of the metal in case there are manufacturers logos stamped into it. Dimensions of the stem size and shape often help, as does more clarity regarding footprint (i…
    0 shabaz over 3 years ago
    Might be hard finding an exact replacement! On aliexpress there are quite a few with three pins on each side so they might be compatible but no idea if the peg at the top would fit or could be modified slightly to make it fit.
    Example below where if it were the same size then it could be possible to solder and then epoxy glue it to secure it perhaps!
  • Gough Lui
    0 Gough Lui over 3 years ago
    We really need measurements, close-ups of the metal in case there are manufacturers logos stamped into it. Dimensions of the stem size and shape often help, as does more clarity regarding footprint (i.e. are any through-holes, or all SMD, shape of leads).
    Closest I came is this:
    https://au.element14.com/e-switch/js1400afq/joystick-sw-5pos-12vdc-0-05a-smd/dp/3883906
    Maybe a variant from the company. But hard to tell.
    - Gough
  • Gough Lui
    +1 Gough Lui over 3 years ago
    Doesn't seem to give me much more to go on.
    - Gough
    • Vote Up +5 Vote Down
  • misaz
    0 misaz over 3 years ago in reply to Gough Lui
    Here is international link: https://www.aliexpress.com/item/1005003682915052.html
  • Gough Lui
    0 Gough Lui over 3 years ago in reply to misaz
    There's a few sellers if one Googles the Sony part number A-2076-368-A it seems ...
    I thought I could make out an A stamped into the switch which made me think of ALPS Alpine but nothing in their catalog seems a perfect match ...
  • cstanton
    0 cstanton over 3 years ago in reply to Gough Lui
    Thanks, I've forwarded these links on Slight smile
  • cstanton
    0 cstanton over 3 years ago in reply to shabaz
    I considered that there may be a similar enough part though I'm not sure they'd be comfortable enough with the level of hackery required.
  • phoenixcomm
    0 phoenixcomm over 3 years ago in reply to Gough Lui
    I just tried it and behold it was in English...
  • javagoza
    0 javagoza over 3 years ago in reply to phoenixcomm
    And it shows it to me in Spanish... despite having the operating system and browser configured to display everything in English. They must be based on the source IP to change the language.
