Ask an Expert Forum TENMA 72-2720 windows 11 USB driver
  • Subscribers 326 subscribers
  • Views 1728 views
See a helpful answer?
JohanDahlberg
JohanDahlberg over 3 years ago
Is there a Windows 11 driver for the TENMA 72-2720 power supply?
The driver currently provided by Farnell/Element14 cannot be used.
I bought this power supply some time ago, but now when I needed to use the USB control I found that Windows can neither identify the device, nor use the drivers provided.
Best regards,
/Johan
    dougw over 3 years ago +3
    You could try Zadig. It worked for my problems with rebranded USB drivers such as Tenma and Multicomp. Jan Cumps put me onto it. https://zadig.akeo.ie/
  • koudelad
    koudelad over 3 years ago +1
    I don't think there will be new drivers. I would suggest using an RS-232 connection instead of the USB (on the power supply side). On PC side, if you don't have a serial port, use a good quality USB…
  • koudelad
    0 koudelad over 3 years ago
    I would suggest using an RS-232 connection instead of the USB (on the power supply side). On PC side, if you don't have a serial port, use a good quality USB-RS232 cable.
    0 dougw over 3 years ago
