Ask an Expert Forum How to know wire polarity in an open circuit without any electrical power?
  • Replies 11 replies
  • Subscribers 335 subscribers
  • Views 11578 views
See a helpful answer?
z234
z234 over 3 years ago
Dear friends, thank you for all your kind help.
How to know wire polarity in an open circuit without any electrical power? E.g. you have a dashcam with 2 wires with same color insulation. How do you know which is positive and which is negative?
If you plug wires wrongly into the battery, a short circuit may happen and damage the dashcam.
How to test for wire polarity in this open circuit then?
Thank you very much
  • Gough Lui
    Gough Lui over 3 years ago +4
    You measure *continuity* using the continuity/ohms setting on your multimeter to determine which of your two same coloured wires go to positive or negative. Alternatively, apply power to one side of…
    Jan Cumps over 3 years ago in reply to z234 +1
    z234 said: How do u see the ohms which is positive or negative by testing continuity? Does the numbers of ohms determine POS or neg ? Ohms can only be positive value. The range is from 0 to infinity…
    0 dougw over 3 years ago
    I would expect if there is no polarity indication that either it doesn't matter (there is a bridge rectifier) or there is a protection diode which wouldn't work in reverse, but wouldn't be damaged either. However I would check by taking it apart. There are some techniques applying low currents and voltages to deduce what is inside, but the decision tree is quite complex - to minimize risk.
