Ask an Expert Forum PyVisa | Trouble I identifying Resources | Rigol DS1054 | Keithly 2200-20-5
  • Replies 23 replies
  • Subscribers 337 subscribers
  • Views 8742 views
  • ask_an_expert
  • USBTMC
  • automation
  • pyvisa
See a helpful answer?
dustin1986
dustin1986 over 3 years ago
Hi I am new to automating lab equipment. I am playing around with an oscope and psu to learn. I am using the usb connections. I am using Manjaro linux. I have the usbtmc driver installed and working. My linux box does see the instruments when I plug them in. However, pyvisa doesnot seem to find them. I just get a long list of ASRL "devices" no way to identify which one is the hardware I attached.
Does pyvisa not see the hardware or is thee another way to find devices?
  • charlieo21
    charlieo21 over 3 years ago +2
    You can try this. i = 1 for key, value in rm.list_resources_info().items(): print('\nInstrument ', str(i), ': ', key) print(' Interface type: ', value.interface_type) print(' Interface board number…
  • baldengineer
    baldengineer over 3 years ago +1
    You need to create a udev rule for USBTMC devices. echo 'SUBSYSTEM=="usb", MODE="0666", GROUP="usbusers"' >> 99-com.rules sudo mv 99-com.rules /etc/udev/rules.d/99-com.rules Make sure you're in "usbusers…
  • baldengineer
    baldengineer over 3 years ago in reply to baldengineer +1
    Also also, "python-usbtmc" (via pip) can give you some troubleshooting information.
  • charlieo21
    You can try this.
    i = 1
        print('  Interface board number: ', value.interface_board_number)
        print('  Resource class: ', value.resource_class)
        print('  Resource name: ', value.resource_name)
        print('  Resource alias: ', value.alias)
        i += 1
  • dustin1986
    dustin1986 over 3 years ago in reply to charlieo21
    Thank. Let me give this a try.
    Jan Cumps over 3 years ago in reply to charlieo21
    On my Windows PC with Python 3.9, that works:
  • dustin1986
    dustin1986 over 3 years ago in reply to Jan Cumps
    [deleted]
    Jan Cumps over 3 years ago in reply to Jan Cumps
    ... and after adding a Rigol PSU:
    I'm preparing for an analogue blog, related to op-amps , Schmitt triggers, and automating the measurements such a circuit. That's why my instruments are currently plugged in and visa-ready Nerd
  • dustin1986
    I get this output ( 32 of them. I am only showing the first 2 because if I post the whole output it gets flagged as spam)
    Instrument  1 :  ASRL1::INSTR
      Interface type:  InterfaceType.asrl
      Interface board number:  1
      Resource class:  INSTR
      Resource name:  ASRL1::INSTR
      Resource alias:  None
    Instrument  2 :  ASRL2::INSTR
      Interface board number:  2
      Resource name:  ASRL2::INSTR
    Jan Cumps over 3 years ago in reply to dustin1986
    Indeed, those are serial entries. It does not seem to pick up the scope
  • charlieo21
    charlieo21 over 3 years ago in reply to dustin1986
    It's possible that is a read only access. Check this python - Unable to get full VISA address that includes the serial number - Stack Overflow
  • dustin1986
    I will check out this possibility as soon as I get back from lunch. Many thanks.
    shabaz over 3 years ago
    This is asking for trouble, having what looks like an entire lab of test equipment all in one network!
    You should ask your lab person to provide separate networks (i.e. separate VLANs) for testbeds, otherwise it's just a matter of time before you interfere with someone else's testbed by accidentally connecting to them.
    If you have a separate network, then your equipment would be nicely isolated.
