Ask an Expert Forum RM9XG sot23-5 component
  • Replies 13 replies
  • Subscribers 335 subscribers
  • Views 2536 views
See a helpful answer?
felipeab79
felipeab79 over 3 years ago
Hello, greetings from Auckland NZ.
I am looking for part number of this component installed on pcb board.
I would appreciate if you can guide me to find this component.
Thanks in advance,
Felipe
  • felipeab79
    felipeab79 over 3 years ago in reply to wolfgangfriedrich +6
    Hi, finally I found the right part No. AP7311-ADJ. Thanks again for your guidance. . it is an adjustable regulator sot25.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to felipeab79 +3
    Great news, that you found the exact part. And thanks for following up and posting the positive result here.
  • wolfgangfriedrich
    0 wolfgangfriedrich over 3 years ago in reply to felipeab79
    Cheers. I might have done a layout or two like this before Slight smile
    Important thing is to not route the ENable connection from pin 3 under the chip, because these regulators come in active high and active low enable. Much easier to cut a trance instead of lifting a pin when things are inverted by accident.
  • felipeab79
    0 felipeab79 over 3 years ago in reply to wolfgangfriedrich
    image. it is an adjustable regulator sot25.
    • Vote Up +6 Vote Down
  • wolfgangfriedrich
