Ask an Expert Forum RM9XG sot23-5 component
  • Replies 13 replies
  • Subscribers 335 subscribers
  • Views 2522 views
See a helpful answer?
felipeab79
felipeab79 over 3 years ago
Hello, greetings from Auckland NZ.
I am looking for part number of this component installed on pcb board.
I would appreciate if you can guide me to find this component.
Thanks in advance,
Felipe
  • felipeab79
    felipeab79 over 3 years ago in reply to wolfgangfriedrich +6
    Hi, finally I found the right part No. AP7311-ADJ. Thanks again for your guidance. . it is an adjustable regulator sot25.
  • wolfgangfriedrich
    wolfgangfriedrich over 3 years ago in reply to felipeab79 +3
    Great news, that you found the exact part. And thanks for following up and posting the positive result here.
  • Gough Lui
    0 Gough Lui over 3 years ago
    Do you have a good macro photo of it?
    More information about the application - what particular board it is used on, would possibly help.
    - Gough
  • cstanton
    0 cstanton over 3 years ago
    You'll need to provide photographs or model and product details so that people know what you're referring to.
  • felipeab79
    0 felipeab79 over 3 years ago in reply to Gough Lui
    RM9sE
    hello, this is one picture good resolution. RM9sE
  • felipeab79
    0 felipeab79 over 3 years ago in reply to felipeab79
    and this is another component, same pcb board, but
    RM9XG
    and this one is the faulty component that I need to replace it. unfortunately I dont have more information about this component. RM9XG
  • felipeab79
    0 felipeab79 over 3 years ago in reply to cstanton
    Thanks for your message. I included some pics.
    0 michaelkellett over 3 years ago
    Wild guessing here:
    You don't show enough in the picture - context is all in this kind of search.
    But I'll guess its made by ROHM (just a hunch from the R)
    If so their codes on SOT23-5 (which they call SSOP5) start with three characters of lot number and then 2 of actual part code.
    So we look up XG on https://smd.yooneed.one/code5847.html
    and find:
    But if it's not a ROHM part then this will be wrong - which is why you need to have some idea of what the part does.
    smd.youneed doesn't list any RM9 parts but does list a whole load of RM parts.
    You need to check the data sheets for them to make sure that you read the marking correctly, then think if the part might be what you've found and then check the connections and values other parts close by.
    How do you know the part is faulty ?
  • felipeab79
    0 felipeab79 over 3 years ago in reply to michaelkellett
    HI, thanks , I appreciate your comments. I checked pcb board and found that connections for
    this component.
     between 1 and 3 there is a bridge that is connected to the power supply (9 volts) and terminal 2 is connected to gnd. I found a short circuit to the power supply, so I checked several components and as soon as I removed this element, power supply and pcb board started.
    Tomorrow I will have a better look to the pcb to get an idea where are terminal 5 and 4 are connected.
  • wolfgangfriedrich
    0 wolfgangfriedrich over 3 years ago
    The RM9sE looks like a adjustable linear regulator with standard pinout:
    1: input with an input cap to GND
    2: GND
    3: enable, active high
    4: FB, feedback with a resistor divider from output voltage - FB - GND
    5: Output with output cap.
    As the trace for the output voltage is not very thick it might be a reference voltage, or an analog voltage feed only a few components. If you find other component pins connected to the same net as pin5, they might have better markings for identification that you get at least an idea of the voltage range of the output voltage.
    The 2nd, RM9xG could be the same/similar component, just a different layout for input, output caps and feedback resistors.
  • wolfgangfriedrich
    0 wolfgangfriedrich over 3 years ago in reply to wolfgangfriedrich
    And there might be a solder bridge between pin 1 and 2 on the RM9sE, if it is not only a shadow or reflection in the image.
  • felipeab79
    0 felipeab79 over 3 years ago in reply to wolfgangfriedrich
    I am impressed....thanks a lot for your accurate analysis. terminal 5 sources with power to a group of components. I will check a good controller to define what could be the output voltage.
