Ask an Expert Forum Calling embedded Linux kernel experts - how do you build a loadable kernel module from the Linux kernel driver repo
  • Replies 9 replies
  • Subscribers 336 subscribers
  • Views 3113 views
  • linux
See a helpful answer?
BigG
BigG over 3 years ago
I seem to be going around in circles here, to what is probably very straight forward.
This issue is probably not that common with Raspberry Pi's as I've noticed on Raspbian that most optional Linux kernel drivers are included by default.
So what I'm seeing is the following.
First we have the official repo for Linux and as you can see there is a stack of drivers available: https://github.com/torvalds/linux/tree/master/drivers
In fact what I am after is already here.
I'll start with a straightforward example, of what I am talking about.
So, let's take a CAN bus module such as the MCP2510. You can find this driver here: https://github.com/torvalds/linux/tree/master/drivers/net/can/spi/mcp251xfd
But this SPI module is not always included by default on your Single Board Computer.
So, the question I have is what is the simplest way to make a loadable linux kernel module (i.e. a .ko file) for this module.
I'm assuming there has to be well proven method of doing this. Please note that I wish to do so without having to recompile the whole kernel.
I know for starters I need to get the Linux kernel headers for my distro.
I've at least done that.
Any tips greatly appreciated.
  • obones
    obones over 3 years ago +3
    Well, the documentation says this: https://tldp.org/LDP/lkmpg/2.6/html/x181.html And then there's the Kernel Newbies community that would be of great help here I believe: https://kernelnewbies.org…
    Jan Cumps over 3 years ago +2
    The AVNET IIOT Gateway Linux includes the MCP251x drivers. I don't know yet how they add it, but their Linux bespoke part is on github: https://github.com/Avnet/smartedge-iiot-gateway
    shabaz over 3 years ago +2
    Hi Colin, I wouldn't normally recommend such an outdated tech book, but it's surprisingly just £3.60 on Amazon currently: It is extremely outdated, but (hopefully) some of it still relevant, although…
  • obones
    0 obones over 3 years ago
    And then there's the Kernel Newbies community that would be of great help here I believe: https://kernelnewbies.org/
  • colporteur
    0 colporteur over 3 years ago
    Sorry for going quiet on you BG. I would have chime in with anything useful. I've done  kernel rebuilds in linux (10 years ago) but haven't done lately. Pi kernel I have never attempted.
  • BigG
    0 BigG over 3 years ago in reply to obones
    Ha. I knew there were real experts here... Two excellent links. Thanks.
  • BigG
    0 BigG over 3 years ago in reply to BigG
    Adding one to the list from the tldp.org website, which I found interesting: https://tldp.org/LDP/lkmpg/2.6/html/x380.html
    0 Jan Cumps over 3 years ago
    0 shabaz over 3 years ago
    Hi Colin,
    It is extremely outdated, but (hopefully) some of it still relevant, although I doubt any of the command lines will work, you will be able to know roughly what to look for.
    There are almost zero books on the topic, so I don't have any more recent book suggestion. It was already outdated when I purchased it too.
    In that old book, it basically states that if the kernel source is in a location /lib/modules/xxxx/build then from wherever your driver source is, there will be a Makefile there, and you'll be able to type something along these lines:
    make -C/lib/modules/xxxx/build M=$PWD modules
    And then to install it, it is the same command but replace modules with modules_install
    The text xxxx is the output of uname -r
    For sure these make commands won't work today, but you can use the links @obones and Jan Cumps  have suggested, to look for the correct current syntax. Makefiles are still used for device drivers.
    0 shabaz over 3 years ago in reply to shabaz
    I just checked another (old) book (not device driver specific), it states a similar-ish Make invocation:
    make -C /kernel/source/location SUBDIRS=$PWD modules
    and then replace the text modules with modules_install as mentioned before.
    And then run depmod -A to update dependencies information.
    idea: maybe we can start a collaborative exercise to:
    1. try to rebuild a raspberry OS
    2. add a driver
    3. do more fancy things
    and document it along the way ...
  • BigG
    0 BigG over 3 years ago in reply to shabaz
    Yep, looks like we've some reading to do.
    Here's another useful reference: www.kernel.org/.../index.html
