Ask an Expert Forum How is this circuit working?
  • Subscribers 335 subscribers
  • Views 1924 views
  • op-amp
  • diy
  • oscilloscope
  • analog
See a helpful answer?
Sudeep AJ
Sudeep AJ over 3 years ago
I am planning to make an DIY oscilloscope. I was looking at other projects and found this circuit which is being used at the Analog front end of the scope. The basic functionality is protection and voltage swing shifting to match the voltage range of the GPIO pin(RPi Pico is being used here)
Project link: https://www.hackster.io/sandy-roberts2/stripboard-oscilloscope-4229ee
I have simulated this circuit in the Multisim Live: https://www.multisim.com/content/UKVp8oVDBb4qX6idoeaCSi/oscilloscope-analog-front-end/open/
So whatever I apply as Vsys voltage(which is 3.3V here) the input voltage will be shifted to 0V to 3.3V level.
The circled voltage is Vsys/2 that whre the zero voltage of the input voltage will be shifted to on the output so that I can capture both +ve and -ve cycles of the input sine.
Can anyone please explain the working of this circuit? And can I use this make my DIY Oscilloscope?
Thank you in advance.
  • kmikemoo
    kmikemoo over 3 years ago in reply to Sudeep AJ +2
    MANY year ago, I build a multimeter from a kit. I learned so much about how multimeters function during that exercise. I did not get anything close to that experience building an oscilloscope kit. Good…
  • kmikemoo
    kmikemoo over 3 years ago +1
    Essentially same post here RE: How it this analog front end circuit working?
  • kmikemoo
  • phoenixcomm
    phoenixcomm over 3 years ago
     Sudeep AJ imageThe first of many problems you are going to have is what is the desired bandwidth of your device. Personally, I have a Tektronix  475A which is quoted from the first page "BEFORE OPERATING" (sorry could not copy and paste so here is the png file made with gimp. You will notice that with a magnifier on I have an effective bandwidth of 1 ns/div! I use this often when trying to nail down ringing ie switch contacts, keyboards, etc. Also, most TTL is 5v rail to rail 3v is floating!
    As a wonderment to see if you can, it will work.
    BTW Beware treat the input stuff as RF!! So shielding is a must! also, my Probes are from Tektronix as well they are shielded and have a 10:1 divider in the probe as well.
    imageNow don't get me wrong, for a toy it is ok, but save some bucks and sweat. Just buy a good scope.  475 can be found on eBay for ~~ 150 & up with out probes.
  • Sudeep AJ
    Sudeep AJ over 3 years ago in reply to kmikemoo
    I am sorry, actually this one I posted links in the question and it got blocked as spam. Then I posted another one with no links.
  • Sudeep AJ
    Sudeep AJ over 3 years ago in reply to phoenixcomm
    Thank you for the information. I am a 3rd year undergrad student now, so I want really want to build even a less BW scope just for the hands on exposure and fun :).
  • kmikemoo
    MANY year ago, I build a multimeter from a kit.  I learned so much about how multimeters function during that exercise.  I did not get anything close to that experience building an oscilloscope kit.     Good luck. Relaxed
