Ask an Expert Forum Water flow sensor
  • Subscribers 337 subscribers
  • Views 743 views
See a helpful answer?
Water flow sensor
FADHLAN2008
FADHLAN2008 over 3 years ago
Hello everyone. Please help...
Can the waterflow sensor when the turbine is rotating the pump is on when the turbine is stationary the pump is off?
    dougw over 3 years ago
    Are you looking for a sensor that indicates the status of the pump?
    What is the flow rate?
    How big is the pipe?
    How do you want the sensor to indicate status? Digital output, analog display, digital display, relay, etc)
  • robogary
    robogary over 3 years ago
    That is what a flow sensor does....   as long as there is a check valve In the piping to prevent reverse flow from suction or gravity during stop condition
