Ask an Expert Forum Monitoring of an event by external interrupt method. Here LCD is not working, can anyone help me please
  • Subscribers 335 subscribers
  • Views 954 views
See a helpful answer?
Md_Enamul
Md_Enamul over 3 years ago
#include <mega32.h>
#include <alcd.h>
#include <stdlib.h>
#define output_ddr DDRB
#define output_port PORTB
char disp[16];
unsigned int i=0, k=0;
void display_lcd(void)
lcd_gotoxy(0,0);
itoa(i,disp);
lcd_puts(disp);
lcd_gotoxy(0,1);
itoa(k,disp);
lcd_puts(disp);
void main(void)
char move=0;
output_ddr=0xFF;
2output_port=0x80;
GICR=(1<<INT1) | (1<<INT0) | (0<<INT2);
MCUCR=(1<<ISC11) | (0<<ISC10) | (1<<ISC01) | (0<<ISC00);
lcd_init(16);
while (1)
if (GIFR & 0x80)
move=2;
GIFR = GIFR | 0x80;
if (GIFR & 0x40)
move=1;
GIFR = GIFR | 0x40;
display_lcd();
if (move==1)
output_port=output_port>>1;
if (output_port==0)
output_port=0x80;
if (move==2)
output_port=output_port<<1;
if (output_port==0)
output_port=0x01;
for (i=0; i<100; i++)
for (k=0; k<3000; k++)
// looping to create a delay
    shabaz over 3 years ago +2 verified
    Your code is not complete. Where are you specifying what GPIO pins are connected to the display? Also, are you running this for real, or in a simulation? If it is for real, then you probably need to…
    +1 shabaz over 3 years ago
    Also, are you running this for real, or in a simulation? If it is for real, then you probably need to change your circuit a bit.
    There must be hundreds of examples of this online that you could examine by the way. Google "atmega32 lcd proteus".
    (There's 54000 hits, surely one of those works).
  • Md_Enamul
    0 Md_Enamul over 3 years ago in reply to shabaz
    I run it for real and simulation,for both LED is working but LCD is not. Thank you for the clarification
